Scale factor of special conformal transformation
stegosaurus
(From Di Francesco et al, Conformal Field Theory, ex .2)
Derive the scale factor Λ of a special conformal transformation.
The special conformal transformation can be written as
x'μ = (xμ-bμ x^2)/(1-2 b.x + b^2 x^2)
and I need to show that the metric transforms as
g'μν = Λ(x) gμν
My attempt was to differentiate the transformation law in order to then use the chain rule (the derivatives are intended as partial):
gσλ=dx'μ/dxσ dx'ν/dxλ g'μν
For a particular partial derivative I get:
dx'μ/dxν = (δμν-2bμxν)/(1-2 b.x + b^2 x^2)- (xμ-bμ x^2)(-2 bν+2b^2 x ν)/(1-2 b.x + b^2 x^2)^2
however plugging this and the other similar term in the chain rule gives rise to a very long expression which does not appear to simplify (I've checked it does in 1D, if all quantities were scalars).
Am I doing something wrong, or am I just missing something?
stegosaurus said:
[...] plugging this and the other similar term in the chain rule gives rise to a very long expression which does not appear to simplify
Oh c'mon, it's not all that "long". (It might seem less intimidating if you used latex and \frac ...)
The combined numerator ends up as a sum of 4 terms, and you can contract some of indices with ##g##.
You'll have to post the whole expression before we can help you figure out what's wrong.
You're right, I made a dumb mistake early on and that prevented me from getting to the final answer! Now I get it.
$$ \frac{\partial x'^\mu}{\partial x^\nu}=\frac{\delta^\mu_\nu-2 b^\mu x_\nu}{1-2(b\cdot x)+b^2x^2}-\frac{(x^\mu-b^\mu x^2)(-2 b_\nu+2 b^2 x_\nu)}{\left ( 1-2(b\cdot x)+b^2x^2\right )^2} $$
is this expression correct?
Afaict, it looks ok to me.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
