Scaling Maxwell's Demon Experiment: Macro-Level Rigid Ball Suspension
The discussion explores the idea of scaling up Maxwell's Demon experiment by substituting gas molecules with rigid, magnet-coated balls suspended in a neutral buoyancy fluid. The concept involves using spherical magnets with varying poles to prevent the balls from touching and interacting. However, it is concluded that this approach would not successfully maintain the motion of the balls. The challenges of achieving the desired dynamics in a macro-level setup are acknowledged. Overall, the proposed method is deemed impractical for replicating the original experiment's principles.
lostminty
I had the concept of scaling up Maxwells' demon experiment to a marco scale.
Replacing molecules of gas with light, rigid, balls. Perhaps coated in magnets with varying poles so they never touch (non-interacting). Would suspend them in a thin fluid with neutral buoyancy.
perhaps you could make a spherical magnet with all the poles passing through its centre.
Wouldn't work. You would not be able to keep the balls in motion.
Thought so. cheers.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
18K
