Scattering angle in relativistic kinematics
1 reply · 3K views · last reply
kalok87
Considering 2 scattering particles with momenta ##p_{1}, p_{2}##, where ##p_{2} = 0## in the Lab reference. The momenta of these 2 particles after elastic collision are ##p_{1}', p_{2}'##, respectively. Due to the 4-momentum relation, we have ##p_{1i}p_{1}^{'i} = e_{1}e_{1}' - p_{1} \cdot p_{1}' = e_{1}e_{1}' - p_{1} \cdot p_{1}' \cos{\theta_{1}}##, here ##\theta_{1}## is the angle of scattering of the incident particle ##m_{1}##, and the ##e_{1}## is the energy of particle ##m_{1}##. Finally we can derive the equation for scattering angle ##\theta_{1}##:
$$\cos{\theta_{1}} = \frac{e_{1}'(e_{1} + m_{2}) - e_{1}m_{2} - m_{1}^{2}}{p_{1}p_{1}'}$$
In Landau's book The Classical Theory of Fields, section 13, a function of ##\theta_{1}## is derived as follows if the rest mass of incident particle ##m_{1}## is larger than the mass of another particle ##m_{2}##:
$$\sin{\theta_{1\, max}} = \frac{m_{2}}{m_{1}}$$
But how could we derive this result?
If we don't consider the relativity, an equation for ##\theta_{1}## can be derived:
$$\cos{\theta_{1}} = \frac{(1 + \alpha) \beta^{2} + 1 - \alpha}{2\beta}$$
where ##\alpha = \frac{m_{2}}{m_{1}}## and ##\beta = \frac{v_{1}'}{v_{1}}##. Since ##\alpha## is a constant, we can find the extreme of ##\theta_{1}## by treating ##\beta## as an independent variable.:
$$ \frac{\mathrm d}{\mathrm d \beta}\cos{\theta_{1}} = 0$$
From above equation we obtain ##\cos{\theta_{1\, min}} = \frac{2\beta}{1 + \beta^{2}}## for ##\alpha = \frac{1 - \beta^{2}}{1 + \beta^{2}}##. Finally we get ##\sin{\theta_{1}}_{max} = \frac{m_{2}}{m_{1}}##.
But if we are considering the relativity, the equation for ##\theta_{1}## is hard to simplify. How can I resolve this? Thank you for the advice.
It is messy, but it will work out. It might be helpful to write the above equation as $$\cos{\theta_{1}} = \frac{ae_{1}' -b}{p_{1}\sqrt{e_{1}'^2-m_1^2}}$$where ##a## and ##b## are certain constants. Show that the derivative of the right hand side equals zero when ##e_{1}' = \large \frac{a m_1^2}{b}##.
