Auto/Motor Schematic for small engine ignition coil
  • Thread starter Thread starter Guineafowl
    Engine Ignition
The discussion focuses on diagnosing issues with small engine ignition coils, specifically those with a charge coil and trigger coil configuration. Participants emphasize the importance of proper testing methods, including checking spark plug connections, coil-flywheel gaps, and ensuring the fuel system is clean and free of water. There are mentions of aftermarket coils providing spark but failing to run the engine, suggesting potential issues with compression or timing. The conversation also highlights the significance of maintaining the correct magnetic gap for optimal ignition performance. Overall, the thread serves as a resource for troubleshooting ignition coil problems in small engines.
Guineafowl
TL;DR Summary
For interest, and to help in testing, I’d like to find a schematic for small engine ignition coils - the type with two magnets on the flywheel passing by the core.
As above. As I understand it, there is a charge coil and a trigger coil, and some circuitry potted in together.
Google: magneto ignition system diagram
jack action said:
How does the following link NOT answer your question?
https://www.google.com/search?q=schematic+for+small+engine+ignition+coils&udm=2
Slightly brusque, I assume from too many posters not bothering to research first. I didn’t put enough in the OP, sorry.
I meant to say I’d already searched, and found much the same results. Almost all of those depict external points or CDI units. The closest one features a third ‘salient’ pole for the trigger coil.
The type I’m interested in is like this, just two poles, a ‘kill’ terminal, and is set against two magnets on the flywheel. These seem to be more common on small garden stuff, but don’t seem to feature in explanations:
To diagnose a dud coil properly, rather than be a parts thrower, I do the following:
1. Remove spark plug and clip a ground lead on, so as not to accidentally stress the coil with an open circuit state.
2. Remove the kill lead and check for spark, check again with known good plug.
3. Check coil-flywheel gap and coil ground connection. Check for spark again.
A few basic multimeter (or even Megger) tests would be useful to know, and for that I need to know what’s inside. With the proliferation of cheaply-made parts, sometimes in genuine boxes, I see quite a few dead/new parts.
Likes jack action
A good philosophy and I did manage to repair an intermittent fault on an old Avenger. The coil went open circuit when hot. Luckily the break was right at the top of the unit and it soldered back OK. But the circuit was 'transitional' (get-attable) with a mix of electronic and mechanical bits and very expensive iirc.
Have you checked the price of a replacement? I'd bet there aren't many different models. How much is your time worth? (I know: nothing and it's for entertainment and that's a priceless commodity)
I imagine that you can't easily get inside so continuity and insulation (but do you have the volts to test that with?).
Cheap enough, about £25/£60 for aftermarket/genuine. Expensive, however, if it’s not at fault, and also takes a few days to arrive.
That’s right - potted in resin. I can do up 1kV DC and 5kV AC megger tests.
@Guineafowl
That is a common occurrence.
If sparks quit only when hot, it should be the coil.
Is that this case?
This link may help:
http://www.dansmc.com/mc_repaircourse.htm
I would also check the plug cap internal connection to the high voltage wire (carbon builds up in there), as well as the kill switch and any other safety switch that connects the CDI to ground in order to kill the sparks.
Is that this case?
After about 20miles the coil was warm enough to expand and pull off the (thankfully visible) connection. Knowing what I was looking for, I located the loose bit with a small screwdriver. I was hard up at the time so it was a relief.
Funny story about it: I used to do a car share and I knew the fault would recover with time (faith). Sure enough,( before I'd actually found the fault) the engine stopped and I apologised but told the passengers it would be OK soon. They laughed like drains but, sure enough it restarted after a while and got us the remaining 20 miles
The coil is dead from cold.
@jack action I can’t see, from those links, an equivalent circuit, unless I’m missing something. I’m looking for two magnetic poles and three connections, kill, earth and spark. The positions of the poles are critical for defining charge and trigger, for ignition timing, and I think there’s some significance in the presence of two magnets, not one, on the flywheel.
Having fitted an aftermarket coil, I have spark, but no run. An occasional spit out of the exhaust or carb is all I can get, even with starter spray.
I have checked:
- flywheel was still keyed in the right place.
- No airflow blockage in exhaust or carb side. It’s getting fuel, as the plug gets wet.
- Compression reasonable, by feel.
So I have spark, fuel, compression, timing and airflow. But it won’t run.
Considering the starter fluid test as diagnostic for a no-spark condition, the only thing I can conclude is that the new coil is able to spark in free air, but not under compression. Genuine coil ordered.
There are forums about pretty well everything and Lawnmowers are popular. It may be worth while dropping a pebble into one of those pools and see what comes back. It could be a well known prob.
On the topic of timing, is it possible that the location of the crankshaft vs the timing detection has come loose? I had this on an old 2stroke motorcycle and it only became obvious when I tightened a screw and the cam fell off. Can you detect any slop?
There may be a coil fault, but how do you know your fuel is good. It may be old and stale, or contain water that wets the plug.
I’ve checked the flywheel is keyed onto the crank correctly. There’s no other scope for timing adjustment.
I did put in some fresh fuel, but the starter spray test (with a cleaned, regapped plug) should have bypassed the fuel side of things.
Replace the coil whenever.
Too much time is wasted with stale and dirty fuel. Drain the fuel, and all the water from the fuel system, clean all the filters, then refill the tank and prime the carburettor with fresh fuel. That is the first thing to do with any small engine that has been sitting, or that does not start reliably.
I have yet to have an engine not start by giving the carburetor a squirt of fresh gasoline providing the ignition is working and timed properly. If it doesn't start then it is ignition related. Not sure what you're using for starter fluid but I've found for gasoline engines that a small squirt of gasoline in the carb is the best.
It may fire and run for a few seconds, but if the carburettor or fuel tank contains water, it will not continue to run. Water in the fuel will break the pull-cord, before they ask me to fix it.
Or if the carburetor orifices are plugged from varnish build-up.
Yes but it proves or disproves the ignition which is what is in question. I could clean the fuel system and put in new and still have the same problem. Pick one system and do it first. Squirt some gasoline in and try it is quick and easy.
Also, I have been in the situation where the engine won't start and I pull the spark plug and found moisture droplets on the plug. It's easy to tell. If that's the case, sure drain the fuel, etc.
Once the ignition fails, the tool sits around until it has breathed in more moist air, condensed that water, and breathed out the volatile fuel components.
If you worked for any time at fixing other people's small engines, the first thing you would do is to check the fuel system. You would do that, even if you suspected the ignition to be faulty. Not checking and changing the fuel is certainly a false economy.
Maybe. I have not and likely will not work on other people's engines for pay. But I know draining and cleaning a fuel system is a guaranteed income for small engine shops. The reason it's done is it is a bit of a guarantee that the unit won't come back that afternoon because it has contaminated fuel. Or at least won't have it until contaminated fuel is poured in from a carelessly placed jug. All shops work that way. It's not worth taking something in unless a certain minimum amount of work is done. I don't think the op is running a commercial business for small engine repair.
Typical lawnmower or small engine shop's spring special:
Drain and replace oil, drain and replace fuel, sharpen or replace blades. Most homeowners utilizing this service don't even bother trying to start the mower or bother looking at the blades. I guess it's a good thing otherwise small engine shops would have a harder time staying in business.
These coils are only transformers.
They have two winding copper coils (one in-lead and one plug- lead), both wrapping a common U-shape iron nucleus and each having a very different number of turns.
The kill switch-lead is only a by-pass of the CDI (connection directly to ground).
Please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/igcoil.html
https://www.denso-am.eu/news/deneur21_04_ignition-coil-basic-principles
https://en.wikipedia.org/wiki/Ignition_coil#Design
https://assets.denso-am.eu/production/news/2021/fig6_446x572.jpg
As your device lacks a battery, the input voltage comes from those rotating magnets inducing the primary winding current (low voltage).
Then, the secondary (high voltage) winding induces the desired spark only when that circuit is suddenly opened (pick-up coil and CDI).
Does that new coil have its own high voltage wire and spark plug cap?
If you had to use the old one, did you check the wire to cap connection for corrosion?
Is this a two-stroke or a four-stroke engine?
Please, see:
https://www.briggsandstratton.com/e...rowse/ignition-system-theory-and-testing.html
It could very well be.
Nevertheless, the ignition coil may not be the weakest link in this case.
In order to produce a healthy spark under compression, we need a strong magnetic field and good electrical connections.
I have seen magnets that have detached from the flywheel due to failing glue, getting tangentially re-located (all packed together).
I have seen magnets that have lost good portion of their originally magnetism.
I have also seen situations in which the recommended magnetic gaps for flywheel and pick-up coils are unable to stay put during operation of the engine (vibrations, loose bolts, heat).
An ignition armature must be set at a precise distance from the flywheel. Your engine repair manual will provide the proper gap for your engine. Common armature gap ranges are .006 - .010" and .010 - .014". Armatures are often packaged with a shim to assist in setting the gap. Index cards of the proper thickness also work well.
The above is from the Briggs and Stratton link provided by @Lnewqban . I had forgotten about this. The proper distance between the flywheel and the stator is important. Also, sand the entire circumference of the flywheel. Get it cleaned up so no rust can bridge this gap. An improper gap may get you spark but it might not get you spark under compression. I have typically used a piece of paper. Hasn't failed me yet and I've done a lot of them. They refer to it as an armature but I think that is incorrect terminology. At any rate, I think we know which piece has to fit where with a paper thin clearance.
@Guineafowl
Why have you not identified the equipment, along with the make and model of the engine?
I know the principles of magneto ignition systems, which are the subject of the links posted, but all of these involve an external trigger. The type I’m dealing with, pictured at the very top, is self-contained and has been fitted to every chainsaw, strimmer (weed whacker?), mower etc that I’ve ever worked on.
The original question was about the internals of this, very common, type of ignition coil, and whether there’s any chance of electrically testing same to confirm dead.
On the diagnostics side, here are some more details:
- It’s a Stihl HS45 2-stroke hedge trimmer. Presented as running this season, but now not.
- I did the checks (post #4) to diagnose a no spark due to faulty coil.
- Once the new coil was fitted, I had spark but no run, so tried starter fluid (easy start).
Even with no carb attached, a sparking engine will fire briefly on easy start. This wouldn’t, and I’d consider that diagnostic for a no spark condition.
In some desperation, I have drained and replaced all the fuel, had the carb apart and blown the various orifices out, and checked the H/L settings. No go. Not surprising because of the easy start test.
Likes Averagesupernova and Lnewqban
^ Just after I posted that, the new, genuine Stihl coil arrived.
Fitted, and the engine started second pull.
So, to close this out, what must have happened is:
- Original coil failed.
- Aftermarket coil sparked in free air, but not in cylinder. I’ve heard of this, but never seen it.
Thanks for the advice, and if anyone knows of a schematic for this particular type of ignition module, I’d still be interested, as this certainly won’t be the last faulty small engine I’ll see.
Guineafowl said:
...and if anyone knows of a schematic for this particular type of ignition module...
It seems you took a bit of heat for this question due to all the resources on the Web. But, none of those resources get to the nitty gritty of what is happening. Yes, we all know how the old points style work and we know the solid state version has to do something similar. But, the question I have is how is the trigger activated as precise as it needs to be. And I'm sure this is part of your question too. With a module that is all in one and relatively easy to replace it is expected that the average joe who replaced it doesn't ask questions. Glad you got it working.
Yes, the links were well-meaning but didn’t capture this type of coil (strictly: ignition module). It’s certainly not a plain transformer, from its function and from the potted form, which looks like it contains a PCB, or at least other components.
I have noticed a certain level of grumpiness on here, not just directed at me. Presumably related to these turbulent times (as pointed out by another member), crackpots, non-Googlers and ‘do my homework for me’ types. On forums, I try to adopt the mantra: what would Jim Hardy do? His thoughtful and encouraging replies (and good-natured scolding, sometimes!) are a model for us all, I think.
Back to the coil, this is a sketch of the flywheel at TDC, roughly gauged with a screwdriver down the bore. The letters ‘N’ and ‘S’ are cast into the aluminium over the magnets, so I assume the field is as drawn. Since rotation is anti-clockwise, it looks like the spark will occur after TDC.
To be clear, there are no other components, points, battery, CDI box, etc., other than the spark plug itself. The spade terminal is simply switched to chassis to kill the spark. Chassis ground is from the core mounts.
  • #31
To be fair we had to wait until post #27 to know that we were dealing with a Stihl HS45. Stating as much information as possible in the first post helps everybody give quality answers quickly.
I'm not an expert on ignition systems and never really worked with small engines, but what baffled me was the two magnets thing. I don't see what the second magnet does. Once I knew the company name, a new search brought me the following images, the first one should be your flywheel where it is not clear that there are 2 magnets, and the second one comes from another machine of the same company that shows that a single-magnet flywheel - along with its ignition module - is replaced by a 2-magnet flywheel. The magnets are 180° apart and the poles are not facing the same direction. The only purpose seems to be giving a higher spark energy.
I also found this:
The use of two magnets in Stihl saw engines offers several advantages. Firstly, having two magnets ensures a more consistent and reliable spark. If a single magnet were used, there could be variations in the strength of the spark generated, leading to inconsistent combustion and potential engine performance issues. Having two magnets helps to eliminate this problem by providing a more balanced and robust spark.
Secondly, the use of two magnets also provides redundancy. If one magnet were to fail or become damaged, the other magnet would still be able to generate a spark. This redundancy is crucial in ensuring that the engine keeps running smoothly, even in the event of a magnet failure.
Additionally, the arrangement of the magnets on the flywheel is carefully designed to optimize their performance. The magnets are strategically placed to ensure maximum magnetic flux and spark generation. This design consideration helps to further enhance the efficiency and reliability of the ignition system in Stihl saw engines.
This seems to mean both magnets are near TDC. Otherwise, how else could one magnet replace the other one in case of failure? Below, they even specify "two or more magnets" which makes me even more baffled; If they are not all near TDC, where are those magnets?
Different models of Stihl chainsaws utilize varying numbers of magnets in their ignition systems. The number of magnets can impact the efficiency and power output of the chainsaw. Chainsaws with more magnets generally produce stronger, more reliable sparks, resulting in improved fuel combustion and overall engine performance.
For instance, Stihl's higher-end professional chainsaw models, such as the MS 661 or the MS 880, typically feature systems with two or more magnets. These chainsaws are designed to handle heavy-duty tasks and demand a high level of power and performance. The additional magnets in their ignition systems ensure a more consistent and powerful spark, enabling them to cut through large logs or tough materials with ease.
Here, they sell a conversion kit from mechanical to electronic trigger module and specify:
The ignition trigger replaces points and the condenser on most chain saws having just two magnets [north and south]. If a flywheel has more than two magnets, then the ignition chip trigger will not work.
I understand that they are talking about a single magnet with two poles when specifying "two magnets [north and south]". But it doesn't tell me how models with multiple magnets work.
  • #32
I believe that your perception on “a certain level of grumpiness on here” is inaccurate.
This is an international forum, in which people of different cultures and carrers come together, on a voluntary basis, to discuss and learn from others, and help if possible.
You don’t know the answer to your original question, but you are certain that all the above “well-meaning” efforts to help where incorrect or misleading.
I hope that, having the opportunity now, you open the useless coil, dissect it, and you understand its functioning parts.
As a token of gratitude to the ones that selflessly, and at the risk of sound grumpy, you could later come back to this thread and explain your findings.
That would be helpful also to the persons facing similar problems, who will read this in future moths and years.
  • #33
I lost faith in believing anything one of the links provided when I read this:
These engines operate on a two-stroke principle, which means that they require both fuel and air to power the combustion process.
Uh, no kidding? So a four stroke engine requires fuel, air and two other things for the combustion process? How about if I were to invent a single stroke engine. Could it run on just air without the fuel? Give me a break. Same low quality answers as anywhere else we've found. We are looking for the type of information we'd get from Jim Hardy. Details that actually tell us something.
If I had taken every answer I've gotten to my questions throughout life at face value when I am pretty sure they were actually non-answers I wouldn't have gotten very far. Just because one doesn't know the answer to a question they are asking does not mean they are unable to spot a bogus answer to said question.
  • #34
The Stihl HS45 happened to be on my bench at the time, and triggered the question, but as I say above, this system is ubiquitous in my experience. Even on four-stroke mowers, where it must be a waste-spark system. The exact machine didn’t seem relevant, only the description given in my first two posts. I will concede it would have made a starting point for research, though.
There’s a grumpy response to my comment on grumpiness! Built up over a few years of seeing it directed at many posters. Not to be taken personally. Please don’t let us argue about that.
From Jack’s post, I see that the two magnets might be for redundancy, so we could analyse the circuit using only one, for simplicity. That photo looks much like my flywheel - I’ve tried to emphasise the two (doodling on pics is a very Jim Hardy thing to do!)
So it looks like one way to find out the answer is to depot the old coil. It’s a hard, black resin, presumably epoxy. Some say methylene chloride to dissolve, some say heat, some say don’t bother. What’s the best way to do it?
  • #35
To me, this is a single magnet, one with two poles, north and south. Here is another representation where the single magnet is more obvious:
Of course, the ignition module contains electronics that replace the contact breaker and capacitor.
Remember when in post #2, I gave you a link to a Google search? Well, here is what I found out from that link that is relevant to your questions:
From https://www.electroschematics.com/555-ignition-coil-driver/ :
From https://forum.arduino.cc/t/need-help-to-drive-an-ignition-coil-with-a-vb921/350723 :
From https://www.rmcybernetics.com/science/diy-devices/diy-ignition-coil-driver :
From https://makingcircuits.com/blog/universal-motorcycle-cdi-circuit-capacitor-discharge-ignition/ :
These all represent the type of electronics that might be present in your ignition module, which also incorporates the coil as well. They, of course, work with steady 12V power, but your circuit must work with the induced power by the magnet, which may also be the positioning signal at the same time. In post #31, there is clearly an electronic module that exists to replace a breaker/capacitor set-up for any mechanical setup. Stihl just incorporated the module with the coil. By adding the term "batteryless" to the Google query, I could find:
From http://gpzweb.s3-website-us-east-1....AndCoilWiring/IgnitionTypesAndCoilWiring.html :
From https://www.electro-tech-online.com/threads/pointless-magneto-internal-schematic.144306/ :
This circuit can be constructed to replace the ign points in a magneto ignition system. Ive fitted it to my Victa 2stroke mower. You just remove the points & condencer, & fit this circuit in its place on the ign coil. Depending on the polarity of the pulse from the coil, the unit may have to be connected the opposite polarity. The circuit is actualy a copy on an Atom Ign module that's no longer produced.​
These are very similar to the circuits I suggested to you in post #8.
But you will never find the exact diagram online as Stihl surely keeps its industrial secrets.
This is why I still think you had the best answer you could ever get in post #2.
  • #36
The 555 ignition coil driver is astable. It will produce a constant arc from the high voltage terminal. Looks to me like someone's driver for a Jacob's ladder. Has no place in an engine ignition. More of the same non-answer crap. EXCEPT for this one:
This one actually eludes to the fact that there is a separate coil that is only for the trigger. That makes sense. It's not difficult to figure an SCR and would be used but this is the only one in this thread that gives a credible attempt at answering the question. Yes I now realize it shows up on the Google link in post #2. But a ways down the list. You would think the other links provided by @jack action would be more informative but I thought they were disappointing. Coming from a supplier of ignition replacement parts I would have expected language that doesn't sound like it's directed towards a kindergartener.
  • #37
Thanks again to Jack for all the searching. I agree with above, it looks like some variant of the two left-hand diagrams, although I’m not sure about the ‘multi-magnet flywheel’, nor how all of that is mounted on one leg of the core, as here:
I doubt that Stihl make their own ignition coils, in fact this one is labelled ‘Walbro’ and as I say, is fitted under various names in so much equipment. Someone knows how it’s made, hence the aftermarket version (which was crap, but I’ve got away with aftermarket coils before).
One thing seems certain - I can test the secondary winding for DC resistance between the HT lead and the core. I also built an inductor ringing tester several years ago, with help from JH and the venerable @Tom.G , which may prove useful, at least for comparison:
https://www.physicsforums.com/threads/testing-windings-tools-gear-for-appliance-repair.915727/
  • #38
I've thought about the two magnet thing as well. I wonder if they are exactly the same. Is one magnet narrower or positioned slightly different so as to charge the capacitor but NOT activate the trigger?
BTW, this is certainly not the first time I've heard of Walbro. Common name in small engine parts. Maybe this particular one is exclusive to Stihl though.
  • #39
Yes, Walbro make small engine carbs as well.
As far as I could see, both magnets were exactly the same. I think if we ever get to analyse the circuit, we can consider them as one, as per Jack’s earlier post.
So, the magnet(s) passes the first pole at TDC. The first pole is the one with all the gubbins around it. I assume the trigger event is the magnet passing the second pole, a few degrees ATDC.
So, we have a charging event, and a trigger event. Somewhere involved is a capacitor and SCR, as with most other CDI ignition systems. We have all the parts, but not total certainty about how they’re arranged.
Likes jack action
  • #40
Depotting with a heat gun wasn’t ideal - although it made the epoxy crumble, it also melted solder joints and destroyed some components. This may not be very informative, but better than nothing.
Firstly, the transformer part, without the PCB. I’ve guessed the secondary is the right-hand bobbin, from the very thin, numerous windings. The primary appears to be split into several sections, perhaps charge/trigger/?.
Next, the PCB as fitted. You can see the kill terminal, and HT lead connection, with PCB slot:
Finally, some of the components on the other side. Two disappeared, so I’ve marked them in. There’s a TO-92 package marked T, transistor/SCR? And possibly another one above it. I stopped there as I was only doing more damage and making a mess.
Could it be, looking at those diodes, that the charge/trigger events are defined by the direction of flux through the core? At a guess, I’d say the unit is charged as the magnet passes the upper leg, then spark is triggered by the magnet passing the lower leg.
Likes Flyboy and Lnewqban
10K
