Schwarzschild de sitter solution
  • Thread starter Thread starter smallphi
    Schwarzschild
smallphi
Where can I find an elementary discussion of the orbits of particles and light rays in Schwarzschild de Sitter spacetime showing the effective radial potential, the rotational speed of circular orbits etc ?
I'm sure I can derive everything mimicking Hartle's textbook treatment of Schwarzschild-only but I need a verified source to compare notes with.
http://prola.aps.org/abstract/PRD/v60/i4/e044006
This looks to be what you want, but it doesn't seem to be on the arXiv.
Yes exactly what I wanted, thanks! It's weird that such a comprehensive study of SdS spacetime appears so late in 1999.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
