Find Inner & Outer Radius of Hollow Circle from Second Moment of Area
  • Thread starter Thread starter kazel101
    Area Moment
To find the inner radius (r2) and outer radius (r1) of a hollow circle using its second moment of area, the equation I=π(r1^4-r2^4)/4 is essential. A simultaneous equation approach is suggested, but additional parameters like the area of the section or the thickness (r2–r1) must be specified to solve for the radii. Without these parameters, multiple solutions for a given value of I exist. Exploring resources on structural mechanics and moment of inertia calculations may provide further insights. Clarifying these parameters is crucial for accurate calculations.
kazel101
TL;DR Summary
trying to solve for cross-sectional dimensions with only I. Need another equation to form a simultaneous equation.
Hi! I am trying to find the inner (r2) and outer radius (r1) of a hollow circle based on its second moment of area. I have the equation that I=π(r1^4-r2^4)/4. I think I need to use a simultaneous equation and then sub this in for one of the radii. However, I am unsure of another equation I could use. Any suggestions would be great of places to look or things I have overlooked.
There are many solutions for any particular value of I.
You need to specify a parameter such as the area of the section, or thickness r2–r1, before solving for r1 and r2.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
