Seesaw mass matrix and neutrino masses
rruben
Hi
Since a few days I've been confused about the seesaw mass matrix explaining neutrino masses. It is the following matrix:
\begin{pmatrix} 0 & m\\ m & M \\ \end{pmatrix}.
As can easily be checked it has two eigenvalues which are given by M and -m^2/M in the limit M>>m (the limit doesn't really matter one is always negative when M and m are positive). It seems really weird to me that you would have a negative mass.
As a lot of papers on the subject (Y. Chikashige, R.N. Mohapatra and R.D. Peccei, Phys. Lett. B98 (1981) 265 and others) will tell you the "mass eigenstates" have masses M and m^2/M without the minus sign. This makes me feel like I'm missing something that makes the sign irrelevant. Could anyone help me with this?
Thanks in advance!
The sign is not irrelevant, it is related to the Majorana phase of the eigenstate. The mass of the particle is the absolute value of the eigenvalue.
Edit: You will notice that also the Dirac mass matrix
\begin{pmatrix}
0 & m \\
m & 0
\end{pmatrix}
has one positive and one negative eigenvalue.
Likes rruben
Thanks for your reply. I will look into it a bit more.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
this thread is to open up discussion on Gravi-GUT as theories of everything GUT or Grand Unified Theories attempt to unify the 3 forces of weak E&M and strong force, and Gravi-GUT want to add gravity. this peer reviewed paper in a journal on Gravi-GUT Chirality in unified theories of gravity F. Nesti1 and R. Percacci2 Phys. Rev. D 81, 025010 – Published 14 January, 2010 published by Physical Review D this paper is cited by another more recent Gravi-GUT these papers and research...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
