Selection Rules for EM Dipole Radiation
Dumbleboar
hey,
I was asking myself a few questions about the selection rules for EM dipole radiation which occurs if electrons "jump" into lower bound states according to the selection rules.
now I know that the full explanation about matrix elements of the dipole operator comes from fermi's golden rule... which I will learn next semester... but apart from that...we have 2 considerations:
1) Parity... parity has to change... ok i got this
2) Conservation of angular momentum:
we have
ji=j\gamma + jf
and we assume that
j\gamma=1
WHY is this angular momentum 1??
I guess it has something to do that the cartesian components of the Dipole operator are proportional to linear compinations of the spherical harmonics Y1,m but I don't get this point at all...
I'd highly appreciate your help!
thanks in advance
Ok Photons have Spin 1... therefore they have j=1
but i guess you can also explain it through expanding the dipole radiation into sperical harmonics and that only those with l=1 can express a dipole or something... could that be it?
Yes, that's correct. I'll skip the derivation and just state that the matrix element for the dipole moment transition is:
\mathbf{r}_{n',n} = \int u_{n'}^*\sum_i\mathbf{r}_i u_n d\tau
I.e. zero unless you have a mean change in location along some axis. (which is intuitive, right?)
Using the rationale from Bethe and Salpeter, the single-electron atom wave-function is:
u_{nlm} = \frac{1}{\sqrt{2\pi}}R_{nl}(r)P_{lm}(\vartheta)e^{im\phi}
So using z = r\cos \vartheta, the matrix element for the transition on the z axis is:
z_{nlm}^{n'l'm'} = \int u^*_{n'l'm'}z u_{nlm} d\tau = \int_0^\infty r^2 R_{n'l'}(r)R_{nl}(r) dr * \int_0^\pi P_{l'm'}(\vartheta)P_{lm}(\vartheta)\cos (\vartheta)\sin (\vartheta) d\vartheta * \int_0^{2\pi}\frac{1}{2\pi}e^{i(m-m')\phi} d\phi
The last integral will be zero unless m = m', in which case it's exactly 1, so \Delta m = 0, and the second integral will vanish unless \Delta l = \pm 1 (a bit trickier, turn the legendre functions into the related spherical harmonics, one of which becomes l \rightarrow l \pm 1. Then you have from the othogonality relations of spherical harmonics that the integral will be zero unless l = l' \pm 1)
And you can of course do the same for any other coordinate and arrive at the same rules.
The \theta equation can be integrated using the following recursion relation
(2l+1)cos(\theta)P_{l,m}(cos(\theta)) = (l-m+1)P_{l+1,m}(cos(\theta))+(l+m)P_{l-1,m}(cos(\theta))
which shows that \Delta l = \pm 1.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
