Sequence {(1/2)ln(1/n)} converge?
  • Thread starter Thread starter garryh22
    Sequence
garryh22
Does the sequence {(1/2)ln(1/n)} converge or diverge?
Working it out analytically, I think it diverges. I would like to know the appropriate test to show this
Seems to me that you can easily show that this diverges from the original definition. I presume that your numerical calculations (I'm not sure what you mean by "analytically". If you have show analytically that this diverges, you are done.) diverges to negative infinity.
That should lead you to look at (1/2)ln(1/n)< -M for M some large integer. Then ln(1/n)< -2M so 1/n< e-2M[/sum] and n> eM. Working the other way, for any integer M, if n< eM then (1/2)ln(1/n)< -M and so the sequence diverges.
Use the simplest test.
lim n -> inf gives (1/2)ln(0) which is not defined and clearly not zero. Therefore it diverges.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
