Sequence that has a subsequence that converges towards any value in R
The discussion explores the existence of sequences that converge to any real value, questioning whether the denumeration of rationals is the only option. It concludes that one can modify existing sequences by removing finite elements or adding infinitely many elements while preserving convergence properties. Alternative sequences, such as those formed from rational multiples of converging sequences, also demonstrate this property. The conversation highlights the flexibility in constructing countable dense sets through various methods, including subdividing the reals at irrational intervals. Ultimately, numerous sequences can achieve the desired convergence to any real number.
Werg22
Is the sequence defined as the denumeration of Q the only such sequence?
Mathematics news on Phys.org
No, you can take that sequence, and remove a finite number of elements or add infinitely many elements and it will have the same property.
A denumeration of the set of rationals of the form n/2^k for all n and k\geq 0 (ie all binary numbers with a finite number of digits) also works.
True. I wonder then, is there such a sequence unrelated to the denumbering of Q?
Depends on what you mean by related. The method of showing denseness and countability will probably be very similar, so much in fact that you'd be inclined to say it's the same thing.
Another countable dense set of the reals is the set of all integer multiples of a sequence of reals converging to 0. Is that good enough? (I wonder if you could change "integer multiples" to multiples of any unbounded sequence*)
Edit: * No you can't. For example, \{1/2^n|n \in \mathbb Z\}\{2^n|n \in \mathbb Z\} = \{2^n|n\in\mathbb Z\} which isn't dense in R.
I believe (tan(n)) works.
there seem to be zilions of them. take any sequence ci=onverging to a given rational, and any sequence converging to another rational, and so on, and take them all.
or instead of the rationals take any countable dense set, eaSILY OBTAINED BY REPEATEDLY SUBDIVIDING THE REALS AT INTERVALS of irrational length, and the union of sequences converging to each one.shoot, almost anything works.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
