Sequences - Assumption that I need to confirm about n approaching infinity
  • Thread starter Thread starter unixmd5crypt
    Infinity Sequences
unixmd5crypt
Find the limit:
an= 2n/(n2+1)1/2
n/a
Because n is approaching infinity, is it OK to disregard the +1 in the denominator and just consider the denominator to be n? This would then divide out the n in the numerator leaving 2 which is the correct answer. I think this is acceptable, but I wanted to run it by you all to confirm. Thank you in advance for your help.
Yes you can consider the limit like that, the '1' becomes negligible as n gets bigger and bigger.
great, that was what I thought but I wanted to make sure that what I got and the correct answer weren't just a great coincidence. Thanks for the fast reply! :)
factor out an n^2 in the denominator in the square root to get: sqrt((n^2)(1+(1/n^2))).
then the problem should be something like: (2n)/[(n)(sqrt(1 + (1/n^2)))].
Apply the properties of a limit taken to infinity and you should get 2 as your limit.
So in essence, you could ignore the 2, but to show why you can ignore it, you can do what I just showed you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
