Servo duty cycle and overdriving
  • Thread starter Thread starter theycallmevirgo
    Cycle Servo
The discussion centers on the service life and operational limits of small hobby servomotors, particularly regarding their torque ratings. Industrial permanent magnet servomotors have two torque limits: RMS (average) torque for continuous operation and peak torque for short bursts. Exceeding the RMS torque requires careful temperature rise calculations, while exceeding peak torque results in irreversible demagnetization of the motor's permanent magnets. Additionally, temperature can affect magnetization, but the demagnetization process is not solely temperature-dependent.
  • Understanding of RMS and peak torque in servomotors
  • Knowledge of permanent magnet behavior and demagnetization
  • Familiarity with temperature effects on neodymium magnets
  • Basic principles of motor operation and torque calculations
  • Research the thermal management techniques for servomotors
  • Learn about the Arrhenius Law and its application in electronic component lifespan
  • Explore methods for calculating shaft load and temperature rise in motors
  • Investigate the effects of different magnet materials on motor performance
Engineers, hobbyists, and technicians involved in robotics, automation, and motor design who seek to optimize the performance and longevity of servomotors.
theycallmevirgo
TL;DR
How can I evaluate duty cycle of small servomotors?
What kind of service life can I expect from small hobby servomotors? Can I exceed current rating for increased power? How will that affect duty cycle?
Thanks so much in advance
Joe
My experience is with industrial permanent magnet servomotors, not hobby motors, so take this accordingly. Industrial servomotors have two torque limits - RMS (average) torque and peak torque. The RMS torque is the allowable torque for continuous operation. The peak torque is the maximum allowable torque for a short time.
Operating at torques greater than RMS torque requires calculating the motor temperature rise over a worst case operation cycle. Shaft load calculations are also required.
Operating at greater than peak torque will instantly demagnetize the permanent magnets. Then the motor is junk, and cannot be repaired.
Thanks so much, very helpful
Is this because of exceeding the Curie temperature?
No. Permanent magnets are manufactured as a non-magnetized block. That block is placed in an electromagnet, which is then energized. The magnetization process is instantaneous, plus the time to build and collapse the magnetic field. One microsecond is more than enough time to magnetize or demagnetize a permanent magnet, so temperature is not involved.
Temperature can also demagnetize a permanent magnet. This is a good discussion of temperature effects on neodymium magnets: https://www.kjmagnetics.com/blog.asp?p=temperature-and-neodymium-magnets.
As a child, I learned how to fix a compass that pointed south. My father wrapped some wire around the compass, and flashed that wire across the car battery. After that, it pointed north.
But demagnetizing (degaussing) an object with remanence (hysteresis) is not so easy. Hence the typical AC degaussing field tapering to shrink the hysteresis loop to zero. So I am confused by how this works. Are you not demagnitizing but just "flipping" the field?
And some of the very newest rare earth megnets have very low Curie Temps....I was shocked.
hutchphd said:
(degaussing)
Brings back memories of degaussing TV picture tubes and computer monitors.
I use Arrhenius Law to inter/extrapolate for a 40'C riseto a 80'C rise. This is how all e-caps are rated for accelerated failure rates. I would avoid the limits of RMS power because there is no cooling mechanism for these products and give margin to the max RMS power being applied. Typically we know life span reduces 50% for every 10'C rise above ambient until some catastrophic melting point or oxidation occurs that causes contamination or whatever.
Yes, I think this is correct. But you are flipping the field in the wrong pattern for good motor operation, particularly if the rotor is moving. Taken as a whole, the magnets may be effectively de-magnetized.
  • · Replies 23 ·
9K
  • · Replies 38 ·
23K
