Proving Uncountability of (0,1): A Puzzling Challenge
  • Thread starter Thread starter aaaa202
    Challenge
aaaa202
The problem is attached as a picture.
I have been trying a lot to prove this without any really fruitful approach. At first I thought that the statement was false, or that you could at least construct a sequence of rationals such that V=(0,1) the following way:
Let a1 be a real in (0,1). Since the rationals are dense there exists a rational number b1 such that d(a1,b1)<ε. Let this be the first rational number in the sequence. Now let a2 be another real. Because the rationals are dense there exists a rational b2 such that d(a2,b2)<ε/2 etc. etc. and by successive use of this method I could generate the whole (0,1) with my approach. But this fails because (0,1) is not countable. So I'm open for any other approach to this problem.
Can you always construct a sequence from the enumeration that converges to an arbitrary ##x \in (0,1)##?
Also, showing it's a proper subset isn't too bad. Can you think of an element in ##(0,1)## that isn't in ##U##?
The statement that you are trying to prove is false (or, rather, not necessarily true) even after fixing it so that epsilon is fixed and the last line refers to V rather than U.
Edit: The problem, as stated, is very poorly posed. Could you maybe copy it verbatim from the source?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
