Set of representable real numbers
The discussion centers on whether the set of representable real numbers can be classified as a set under ZF axioms, with participants debating the implications of definability and first-order logic. One participant proposes a proof that the class of definable subsets of real numbers can be constructed as a set, relying on the axiom of separation. However, challenges arise regarding the quantifier step and the definition of a class, particularly in relation to first-order logic statements. The conversation highlights the complexity of defining representable real numbers and the necessity of arithmetizing the language to align with ZFC formulas. Ultimately, the discourse reflects the intricate relationship between logic, set theory, and the nature of definable numbers.
Office_Shredder
Staff Emeritus
From what I understand, the class of all real numbers that we can represent as a sentence in logic is countable. But I'm not sure if it's a set under the standard ZF axioms... it seems intuitive that it should be, since the axioms are really designed to prevent problems involving sets that are too large, and countable sets are fairly innocent, but was wondering if anyone knew one way or the other.
Well, every subclass of a set is a set, according to the axiom of separation, but the question is whether the set of definable/representable real numbers is a class, i.e. can be defined by a formula of set theory.
Here's my attempt at a proof: the class of all formulas of set theory is clearly a set (it can easily be defined inductively). Now if there is a class function f: formula phi -> the subset of R defined by phi, then (because the image of a set is a set) the class of all definable subsets of R is a set. Being a singleton set is a definable condition, so we take the intersection of this class and the class of singletons. We take the union of this set to get the set of definable real numbers. So we need to construct the function f, but this can be done inductively (unless I'm mistaken). Therefore, the definable reals form a set.
Only if they can be described as satisfying a first order logic statement right? According to wikipedia, no such statement exists for the definable reals.
Yes, which is what I said and then went on to attempt a proof without using the presupposition that the definable numbers form a class.
ETA: every class is definable by a first-order formula of set theory, so your "only if they can be described as satisfying a first order logic statement" is merely a restatement of the assumption that it's a class.
ETA 2: to try to make the construction of f explicit: f(x \in a) = a, f(\neg\varphi)=\neg f(\varphi),f(\varphi \wedge \psi) = f(\varphi) \cap f(\psi), f(\exists y \varphi(x,y))=\cup_{y \in V} f(\varphi(x,y))
The quantifier step doesn't work as it is, I can't figure out how to fix it right now, but intuitively speaking it should be possible, as first-order logic can be immersed into set theory.
I think the problem is we're defining class differently. I think I see what you're saying there
You're looking at:
{x in R : there exists phi s.t. "phi is a formula" and "there exists unique y in R s.t. V models phi[y]" and "V models phi[x]"}
The condition for x to be in this set doesn't look like a formula of ZFC, but you can probably arithmetize the language such that it becomes equivalent to a formula of ZFC, e.g. (there exists phi s.t. "phi is a formula") is equivalent to (there exists n s.t. n is in the set of Godel numbers of ZFC formulas) where the set of Godel numbers of ZFC formulas is somehow definable.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
