Shear Stress in Beams: Proof & Explanation
The discussion revolves around the calculation of shear stress in beams, specifically addressing the formula for shear stress and the correct computation of the statistical moment of area (Q). Participants explore the reasons behind the maximum shear stress occurring at the neutral axis of a beam and seek proof or clarification on this point.
  • Homework-related
  • One participant presents a formula for shear stress and questions why it is maximum at the neutral axis, requesting proof.
  • Another participant attempts to derive the formula for Q and expresses uncertainty about their calculations, suggesting a different approach to computing Q.
  • Several participants assert that the original author's calculations for Q are correct and emphasize the need to use the correct variables when determining Q.
There is disagreement regarding the calculation of Q, with some participants asserting the correctness of the author's method while others believe their own approach is valid. The discussion remains unresolved as participants have differing views on the calculations involved.
Participants have not fully clarified the assumptions underlying their calculations, particularly regarding the definitions of variables and the method of calculating the centroid of the area in question.
filterwin9
where
V = total shear force at the location in question;
Q = statistical moment of area;
t = thickness in the material perpendicular to the shear;
I = Moment of Inertia of the entire cross sectional area.
based on this formula , the shear stress is max at the neutral axis of beam ... Why it is so ? Can someone prove me ?
The author's working is correct. You are not calculating Q correctly. Q is the area below the section of interest time the distance from the centroid of that area to the neutral axis. Use y1, not y, when calculating the area and the distance of the centroid of that area to the neutral axis.
solved
13K
  • · Replies 16 ·
