Danyon
- 83
- 1
If I surrounded a wire carrying current with a superconductor would the magnetic field from the wire be blocked from the outside?
Shyan said:If while the current is flowing, you surround it with a superconducting material, then no, it doesn't block the magnetic field. But if you surround the circuit with the superconducting material first and then start the current flow, then yes, it will block the magnetic field.
A material in the superconducting state tends to keep the magnetic flux through it, constant. So if, when enters the superconducting phase, there is no flux through it, its going to keep the flux zero. So when you start the current flow and the magnetic field is created, the material will induce currents in itself to cancel the magnetic field from the circuit and keep the flux constant(which is zero in this case).Drakkith said:What's the difference between the two scenarios that causes this?
Shyan said:At first I should correct that the material shouldn't be in the superconducting state before placing it there. So how it should be done, is first surrounding the circuit with the material, then cooling the material for it to make transition to the superconducting state and then start the current flowing.
ZapperZ said:This is confusing. It appears that you are mixing up superconductivity with perfect diamagnetism.
It doesn't matter if the there is already a magnetic a field or not. A superconductor will shield off the magnetic so field via the Meisner effect, IF the superconductor is a a Type I or below the lower critical field.
Zz.
Zz.
