How can I double the distance of a pulled object using a scissor system?
  • Thread starter Thread starter Lex1138
    Pull
A user is developing a school project requiring a system where a pulled object moves twice as far as the pulling object. They recall a pulley system that could achieve this but need assistance in identifying it. Suggestions include searching for "block and tackle" systems. Ultimately, the user decides to utilize a scissor system for their project, believing it to be the most effective solution. The discussion highlights the importance of exploring different mechanical systems for achieving specific movement ratios.
Lex1138
I'm working on a project for school and I have to come up with a system where a pulled object moves twice as far as the object doing the pulling. I think I've seen a pulley system that can do this, but I can't remember where. If anyone has any suggestions, I would greatly appreciate it.
Have you searched on "block and tackle"?
Thanks for your replys, I think I'm going to go with a scissor system. I think that may work best in my project.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
