Is the Inequality a+b <= a^2/b + b^2/a Easy to Prove?
  • Thread starter Thread starter nicksauce
    Proof
The inequality a + b ≤ a²/b + b²/a for positive a and b can be proven by simplifying it to show that (a + b)(ab) ≤ a³ + b³. When assuming a < b, the proof leads to the conclusion that b² ≤ a², which holds true since the square function is strictly increasing for positive values. The discussion highlights that equality occurs when a equals b, while the inequality holds when a and b are different. The approach of factoring the right-hand side is suggested as a potentially easier method for proving the inequality. Overall, the proof demonstrates the relationship between the variables under the given conditions.
nicksauce
Homework Helper
Show that for all positive a,b
This simplifies to showing that
(a+b)(ab) <= a^3 + b^3
a^2b + b^2a <= a^3 + b^3
But I'm not really sure where to go from here... any hint would be appreciated.
It's Interesting that a+b = a^2/b + b^2/a when a=b.
So I might presume that a+b < a^2/b + b^2/a when a not equal b.
Try b = a + epsilon, and eliminate b.
Apply it to a^2b + b^2a <= a^3 + b^3.
How does this look?
As noted, if a = b we have equality. Since the original expression is symmetric in the two variables, we can assume W.L.O.G. that a &lt; b.
Then
<br /> \begin{align*}<br /> a+b &amp; \le \frac{a^2}{b} + \frac{b^2}{a} \\<br /> \intertext{if and only if}<br /> a^2b + ab^2 &amp; \le a^3 + b^3 \\<br /> \intertext{if and only if}<br /> ab^2 - b^3 &amp; \le a^3 - a^2 b \\<br /> b^2(a-b) &amp; \le a^2 (a-b) \\<br /> \intertext{if and only if}<br /> b^2 &amp; \le a^2<br /> \end{align*}<br />
and, since the square function is strictly increasing on the positives, the final statement is true if and only if a &lt; b.
Since equality holds when the two are equal, and inequality holds when they are not, we are done.
Perhaps it would have been easier to start with nicksauce's idea:
Try factoring the RHS.
Easier? Nay, infinitely easier (well, not infinitely, but much easier).
That's the problem with proofing one's own work - you get wrapped up and can't see the trees for the forest. Good point Gib Z.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
