Show that a definite integral is positive
The discussion centers on proving that the definite integral \(\int_0^1 {x^n \sin \left( {\frac{{\pi x}}{2}} \right)} dx > 0\) for all \(n \ge 0\). The integrand consists of two functions, \(x^n\) and \(\sin\left(\frac{\pi x}{2}\right)\), both of which are positive over the interval (0,1). The initial approach using inequalities was deemed insufficient due to the non-monotonic nature of the sine function, which can lead to incorrect conclusions. A more robust proof is recommended, emphasizing the positivity of the sine function within the specified bounds.
  • Understanding of definite integrals and their properties
  • Familiarity with trigonometric functions, particularly sine
  • Knowledge of inequalities and their application in mathematical proofs
  • Basic calculus concepts, including limits and continuity
  • Study the properties of the sine function, particularly its behavior in the interval \((0, \frac{\pi}{2})\)
  • Learn about monotonic functions and their implications in calculus
  • Explore rigorous proof techniques in calculus, focusing on integrals and inequalities
  • Investigate other methods for proving positivity of integrals involving trigonometric functions
Mathematics students, educators, and anyone interested in understanding the properties of definite integrals and trigonometric functions in calculus.
danago
Show that \int_0^1 {x^n \sin \left( {\frac{{\pi x}}{2}} \right)} {\kern 1pt} dx > 0 for all {\rm{n}} \ge {\rm{0}}
Basically, what i want to show is that over the interval (0,1), the integrand is above the x-axis, or positive. I will show that over the interval, both functions, x^n and sin(\frac{\pi x}{2}) are both positive.
For the trig function, this is how i proceeded:
<br /> \begin{array}{l}<br /> 0 &lt; x &lt; 1 \\ <br /> 0 &lt; \frac{{\pi x}}{2} &lt; \frac{\pi }{2} \\ <br /> \sin 0 &lt; \sin \left( {\frac{{\pi x}}{2}} \right) &lt; \sin \left( {\frac{\pi }{2}} \right) \\ <br /> 0 &lt; \sin \left( {\frac{{\pi x}}{2}} \right) &lt; 1 \\ <br /> \end{array}<br />
Is that a valid way of doing it?
For the xn function, i took the same approach:
<br /> \begin{array}{l}<br /> 0 &lt; x &lt; 1 \\ <br /> 0^n &lt; x^n &lt; 1^n \\ <br /> 0 &lt; x^n &lt; 1 \\ <br /> \end{array}<br />
Since, over the interval of (0,1) of which the function is being integrated, the integrand is positive, the definite integral will be positive for all values of n.
My main question though; Is my approach a good way of doing such a problem? It seemed to work fine for this question, but are there cases where i can't use such a method?
My book has this for an answer:
Let g(x)=x^n and h(x)=sin(\frac{\pi x}{2}).
On the interval 0 < x < 1 , g(x)>0. On the same interval, h(x)>0, therefore, the definite integral is greater than zero.
That is basically the concept i used, but i really don't like that method, since it really doesn't show much, and in exams, depending on the marker, i may lose marks for such a bland proof, which is why I am wanting to use a more solid proof.
Thanks in advance,
Dan.
EDIT: Just realized that this method using the inequalities does not work for all cases. But it should work if the function is strictly increasing, or strictly decreasing over the interval, right?
danago said:
Show that \int_0^1 {x^n \sin \left( {\frac{{\pi x}}{2}} \right)} {\kern 1pt} dx &gt; 0 for all {\rm{n}} \ge {\rm{0}}
No. Consider using your logic to get the following obviosuly wrong result:
<br /> \begin{array}{l}<br /> 0 &lt; x &lt; 1 \\ <br /> 0 &lt; \pi x &lt; \pi \\ <br /> \sin 0 &lt; \sin \left( \pi x\right) &lt; \sin \left( \pi \right) \\ <br /> 0 &lt; \sin \left( \pi x \right) &lt; 0 \\ <br /> \end{array}<br />
Don't try to do a proof with usual manipulation of inequalities when you have trig functions like this because trig functions are not monotonous, they increase and then decrease and so on.
You should simply state it as an obvious fact that for an argument between 0 and pi/2, the sin function is always positive.
  • · Replies 105 ·
  • · Replies 40 ·
