Show that the Internal Energy of an Ideal gas is a Function of T only
The internal energy U of an ideal gas, described by the Clausius equation of state P(V-b) = RT, is solely a function of temperature T. This conclusion is reached by demonstrating that both partial derivatives, ∂U/∂V and ∂U/∂P, equal zero at constant temperature. The derivation utilizes the thermodynamic equation of state and the relationships between pressure, volume, and temperature, ultimately confirming that U does not change with respect to volume or pressure for this gas model.
  • Understanding of the Clausius equation of state for ideal gases
  • Familiarity with thermodynamic equations and partial derivatives
  • Knowledge of the relationships between pressure, volume, and temperature in thermodynamics
  • Basic calculus skills for differentiation
  • Study the implications of the first law of thermodynamics on internal energy
  • Learn about the Maxwell relations in thermodynamics
  • Explore the concept of heat capacity and its relation to internal energy
  • Investigate real gas behavior and deviations from ideal gas laws
Students and professionals in physics and engineering, particularly those focusing on thermodynamics, ideal gas behavior, and energy systems.
knowlewj01
Show that internal energy U = U(T) only for an ideal gas who'se equation of state is:
P(V-b) = RT
(the claussius equation for n moles of gas)
Thermodynamic Equation of state:
\left(\frac{\partial U}{\partial V}\right)_T = T\left(\frac{\partial P}{\partial T}\right)_V - P
so, basically we need to prove that for this gas the following criteria are met:
\left(\frac{\partial U}{\partial V}\right)_T = \left(\frac{\partial U}{\partial P}\right)_T = 0
internal energy U does not change with respect to P or V.
using the equation of state of the gas, we can differentiate P with respect to T at constant V:
\left(\frac{\partial P}{\partial T}\right)_V = \frac{R}{V-b}
now substitute this into the thermodynamic equation of state:
\left(\frac{\partial U}{\partial V}\right)_T = \frac{RT}{V-b} - P
and from the equation of state of the gas, we can obtain P:
P = \frac{RT}{V-b}
so the result is that \left(\frac{\partial U}{\partial V}\right)_T = 0
thats half the work done, I am not sure how to prove \left(\frac{\partial U}{\partial P}\right)_T = 0
any pointers? Thanks
Just read some more notes on this, does the fact that
imply that:
if so, why is this? i can't see why
starting from the thermodynamic equation of state:
rearrange it to get \left(\frac{\partial U}{\partial P}\right)_T
dU = T\left(\frac{\partial P}{\partial T}\right)_V dV - P dV
\left(\frac{\partial U}{\partial P}\right) = T\left(\frac{\partial P}{\partial T}\right)_V \left(\frac{\partial V}{\partial P}\right)_T - P\left(\frac{\partial V}{\partial P}\right)_T
now using the equation of state of the gas find dp/dt and dv/dp
\left(\frac{\partial V}{\partial P}\right)_T = -\frac{RT}{P^2}
substitute back in:
\left(\frac{\partial U}{\partial P}\right)_T = - \left(\frac{RT}{P^2}\cdot \frac{RT}{V-b}\right) - \left(-\frac{RT}{P}\right)
\frac{RT}{V-b} = P
so
\left(\frac{\partial U}{\partial P}\right)_T = -\frac{RT}{P} + \frac{RT}{P} = 0
  • · Replies 21 ·
  • · Replies 23 ·
