Show that this set of equations defines a unique vector
  • Thread starter Thread starter 1MileCrash
    Set Vector
1MileCrash
Show that, given vectors A and B:
A * X = |a|
and
A x X = B
defines X as a unique vector
No idea.
My only conclusion thus far is that the magnitude of x is equal to 1/cos(theta) where theta is the angle it makes with vector A.
Any ideas?
A * X = |a|
and
A x X = B
No idea.
Any ideas?
It appears that you're being a bit careless with upper/lower case.
If you mean AX = |A|,
then, yes, the magnitude of vector, X, is given by |X| = 1/cos(θ) .
So, it looks like you used CD = |C| |D| cos(θ) .
Now use that the magnitude of the vector product is:
|C × D| = |C| |D| sin(θ)
Sorry! Yes, I tried to make all vectors upper case afterwards to prevent confusion with the cross product.
I have also noted the magnitude of the cross product to be |A||X|sin(theta) = |B| but I am not sure how this relates to finding anything out about X, since I already know its magnitude based on theta above, and I know nothing about B other than it being perpendicular to both A and X.
And what is |X| ?
Ah!
So then that results in
Tan(theta) = |B|/|A|
So it's direction relative to A is
arctan(|B|/|A|)
And it's magnitude is
1/cos(theta)
Which is of course:
1/cos(arctan(|B|/|A|)
Geometrically, I figure that cos(arctan(x)) = (x^2 + 1)^(-1/2)
So 1/cos(arctan(x)) = (x^2 + 1)^(1/2)
Then letting x = |B|/|A|,
The magnitude must be
\sqrt{\frac{|B|^{2}}{|A|^{2}} + 1}
And its direction relative to A must be
arctan(\frac{|B|}{|A|})
Hm... but arctan will give the same thing for some angle theta, and 180 - theta. So it's still not unique.. this must be resolved some way?
Thanks for the help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
