Showing this Euler's equation with a homogeneous function via the chain rule
15 replies · 5K views
lo2
Ok I have this general homogeneous function, which is a [itex]C^1[/itex] function:
[itex]f(tx,ty)=t^k f(x,y)[/itex]
And then I have to show that this function satisfies this Euler equation:
[itex]x\frac{\partial f}{\partial x}(x,y)+y\frac{\partial f}{\partial y}(x,y)=k\cdot f(x,y)[/itex]
Ok so I have tried to take the derivative, and I get:
[itex]x(1\cdot t+1\cdot 0) + y(1\cdot 0+1\cdot t)=xt+yt[/itex]
But that does not really do the trick, so am I on the right way? And if so what more should I do?
clamtrox said:
Differentiate f(tx, ty) with respect to t
But I have this equation:
Where I have to differentiate first with regards to x and then y. So am I not sure I can see how I should just differentiate with regards to t.
It's a straightforward application of the chain rule... ∂f(tx,ty)/∂t = ∂f(tx,ty)/∂(tx) ∂(tx)/∂t + ∂f(tx,ty)/∂(ty) ∂(ty)/∂t ...
After you got that, then differentiate the other side, tk f(x,y) and then consider what happens when t→1.
Ok so I get this when I differentiate [itex]f(xt,yt)[/itex]:
[itex]\frac{\partial f}{\partial t}(xt,yt) = 1\cdot x + 1\cdot y = x + y[/itex]
But I am not sure how to differentiate:
[itex]t^k f(x,y)[/itex]
Shall I once again differentiate with regards to t?
That is not right. Can you understand the formula in my previous post? That tells you how it goes.
Yes... The point is to keep the equality
f(tx, ty) = tk f(x,y), therefore
∂f(tx, ty)/ ∂t = ∂/∂t (tk f(x,y))
Well I guess not, I am not sure what this differentiates up to be:
[itex]\frac{\partial f}{\partial tx}(tx,ty)[/itex]
The other one I think I got correct?
[itex]\frac{\partial f}{\partial t}(tx) = x[/itex]
I do not want to seem rude.
But might someone else perhaps chip in with a little bit of help?
Would be most appreciated! :)
Yeah I guess that looks a little tricky. If you want, you can also write it as [itex]\frac{\partial f(a,b)}{\partial a}[/itex] evaluated at a=tx.
Well I must admit that I am still not sure how to compute that.
As you do not know what the function is, and thereby I find it hard differentiate...
Ok I think I have got something:
If we first differentiate
[itex]f(tx,ty)[/itex]
We get:
[itex]x\frac{\partial f}{\partial xt}(xt,yt)+y\frac{\partial f}{\partial yt}(xt,yt)[/itex]
And since this has to be equal to
[itex]k\cdot f(x,y)[/itex]
We have that
[itex]t^k[/itex]
Can only be a constant when [itex]t=1[/itex], so if we do that we get:
[itex]\frac{df}{dt}=x\frac{\partial f}{\partial x}(x,y)+y\frac{\partial f}{\partial y}(x,y)=1^k f(x,y)=k\cdot f(x,y)[/itex]
Ok well I kind of have to go soon, so if you would please have a short glance at my suggested solution, I would be more than happy!
I couldn't quite follow that last post. Are we sure you are not assuming there what you have to prove?
I may have a mental blockage; am not sure that you can or are meant to prove 2 from 1.
The only 'homogeneous functions' I know are homogeneous polynomials which are things of form
f(x, y) = Ʃ arxryk-r (r from 0 to k)
Get the two derivatives of that and you'll see it's easy.
Ok well I am not exactly sure what you mean here, but if you are asking what it is I need to show then it is:
lo2 said:
We get:
Good!
No! :) It has to be equal to k tk-1 f(x,y). This has to hold for any value of t, and in particular for t=1, which is the case you're interested in.
