Side channel on the headphone jack
  • Thread starter Thread starter keystroke
    Channel
The discussion explores experiments with an oscilloscope connected to a laptop's headphone jack, revealing distinct waveforms when the battery is charged or full. Users suggest utilizing a signal generator program to output various waveforms and consider capturing RGB sync signals from the VGA output. There is curiosity about whether data can be extracted from the headphone jack when no audio waveform is present, referencing research on signal extraction techniques. The conversation highlights the potential for innovative experiments in signal processing and data extraction from electronic components. Overall, participants are eager to explore the intersection of hardware signals and data analysis.
keystroke
I'm playing around with an oscilloscope and my laptop's headphone jack. I get the tip/ring/ground and measure between them. I also measure between them and an external reference ground. I notice I can see when the battery is charging. That is, if the battery is not in the laptop but the AC is in, then I insert the battery, it runs through some software or something in the battery for a few seconds and then if the battery is not full, it goes to a waveform - if it is full, it goes to another "quieter" waveform.
I am just doing this for fun. Can anyone think of interesting experiments I can do? I would like to see about extracting signal from the noise of the waveform.
Thanks!
You can download a signal generator program. That would let you output various waveforms from the computers audio card. Depending on the type of scope you could also try to pick up the RGB sync signals from the computers VGA output. There are a lot of things you could look at.
Thanks dillonjerry. Might there be any data present in the signal on the headphone jack if I am not putting out an audio waveform? ie. by virtue of the circuit passing through some of the data processing elements of the motherboard.
For instance in a way similar to the paper published here:
https://www.defcon.org/images/defco...on-17-barisani-bianco-sniff_keystrokes-wp.pdf
or
http://cs.tau.ac.il/~tromer/acoustic/ (Here the noise comes from a bank of 1500µF capacitors).
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
