Sign of u and v in a complex variable
Fixxxer125
if z=x+iy and sqrt(z) = u+iv
u=±(1/√2)*√(x+√(x^2+y^2 ))
v=±(1/√2)*√(-x+√(x^2+y^2 ))
How must the signs on these result be chosen?
2. The attempt at a solution
I wondered if it was something to do with ensuring √(z) was always positive, but then ruled this out as it is a complex function. I don't really know where to do with this one! Thanks for your help
Hi Fixxxer125! :smile:
Fixxxer125 said:
if z=x+iy and sqrt(z) = u+iv …
Do the obvious …
square the second equation: x + iy = z = (u + iv)2,
then equate real and imaginary parts (separately). :wink:
Ah brilliant, thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
