Signal attenuator controllable by UDP,TCPIP?
  • Thread starter Thread starter paul120
    Signal
To simulate digital television picture breakup for a degree project, an automated signal attenuator is needed to control attenuation via software on a PC. The proposed setup includes a USB TV receiver connected to a signal attenuator with a serial input for software control. While manual attenuators are available, the focus is on finding a digital solution that allows for automation. Suggestions include building a serial to parallel interface, possibly using a BCD converter, which can be sourced from surplus equipment. The discussion emphasizes the importance of hardware compatibility for successful automation.
paul120
Hello as part of a degree project I need to simulate digital television picture breakup, as demonstrated when the signal level is low or interferred with. I have found manual attenuators which are quite cheap but I need to automate the process with software on a pc. Is there anyway possible of acheiving this?
I envisage a pc running a usb tv receiever, the aerial coax cable plugged into a signal attenuator, the signal attenuantor having a serial input which allows the attenuation to be controlled via software on the PC. the software side is not an issue, merely the harware.
Many thanks
Digital attenuators were common place when I was doing RF. May need to build a simple serial to parallel interface, maybe with a convertor to BCD. These should be available surplus, based upon the magnitudes of quantity that I have seen scrapped.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
