Shay10825
- 338
If I measured something to be 43.49 centimeters with a meter stick and I wanted to convert that into meters, would it become 0.4349 cm or 0.43 cm??
Thanks
Thanks
andrewchang said:keep the same number of sig figs
Shay10825 said:So it would be 0.4349 cm because 0.4349 cm and 43.49 m have 4 sig figs?
Significant figures are the digits in a number that carry meaning or contribute to its precision. They are used to express the level of uncertainty or precision in a measurement or calculation.
To calculate significant figures, you must first identify the non-zero digits and any zeros between them. Then, count the total number of digits and round to the desired number of significant figures based on the rules of rounding.
Significant figures are important because they help communicate the precision and accuracy of a measurement or calculation. They also ensure that calculations are carried out with the appropriate level of uncertainty.
To convert from centimeters (cm) to meters (m) while maintaining significant figures, you must divide the number of centimeters by 100. The final answer should have the same number of significant figures as the original number of centimeters.
The correct way to write 43.49 cm in meters with the appropriate number of significant figures is 0.4349 m. This maintains the original number of significant figures, as 43.49 cm has four significant figures.
