Signs in the equation, angular acceleration
The discussion centers on the relationship between angular acceleration (α) and linear acceleration (a_g) using the formula a_g = α * r. Participants clarify that while the formula provides the magnitude of acceleration, the signs must be considered in the context of vector equations. The right-hand rule and consistent application of conventions ensure correct sign determination. It is established that using vector methods is preferable for accuracy, especially when dealing with varying directions of acceleration.
  • Understanding of angular acceleration (α) and linear acceleration (a_g)
  • Familiarity with vector equations and cross products
  • Knowledge of the right-hand rule for vector direction
  • Basic principles of rotational dynamics and Newton's second law (F = m * a)
  • Study vector calculus to deepen understanding of cross products in physics
  • Learn about the right-hand rule and its applications in rotational motion
  • Explore the implications of scalar versus vector quantities in physics
  • Investigate advanced topics in rotational dynamics, including torque and moment of inertia
Students of physics, particularly those studying mechanics and dynamics, as well as educators seeking to clarify concepts of angular and linear acceleration.
Bauxiet
Counter clockwise is positive, right is positive and up is positive.
My problem statement: When I use the formula ag = alfa*r do I have to take signs into account? Or is this formula just for the magnitude and will the signs be already taken into account in other equations? (F= m*a for example)
Ag = alfa*r (gravity point acceleration)
F = m*a
M = I*alfa
alfa = angular acceleration
I am a little bit confused. In the exercise underneath I did not and I became the right solution. I think this formula gives the magnitude, the signs are already taken in account in other equations where you fill in the ag = alfa*r. Is this right?
The underneath picture is as an example. Look at the highlight. My alfa is negative (angular acceleration) and my ag (aA in this case) is positive. Ag is the acceleration of the disk. IF I had taken the negative sign of the alfa into account, that would mean that my Ag would be negative, which is not the case!
Is this right? Correct me if I am wrong, thank you!
The relationship between acceleration, angular acceleration and radius is best considered as a vector equation, and in that view it involves cross products. There are various conventions, such as the right-hand rule, regarding the order of arguments to the cross products and the positive directions for the vectors. When all the conventions are used consistently, the correct sign comes out.
Similarly for velocities.
However, it is not a simple conversion of Acceleration = angular acceleration x radius to vector form, like maybe: ##\vec a=\vec \alpha \times\vec r##. (Clearly, because that would not register any acceleration for a purely radial acceleration.)
E.g. for velocity the equation is ##(\vec r.\vec r)\vec \omega=\vec r \times \vec v##.
If working with scalars, I do not know a better way than simply reasoning out the sign of the result.
Edit: Or maybe...
In the special case where the radius is constant, we can differentiate the velocity equation to get
##(\vec r.\vec r)\vec \alpha=\dot{\vec r} \times \vec v+\vec r \times \dot{\vec v} = \vec v\times \vec v+\vec r\times\vec a= \vec r\times\vec a##.
Edit: Or maybe...
Thank you! If I use the vector method I become indeed a positive number. This method can always be used? Also If I am working not with vectors as in my picture above?
And if I work with scalars, your method is just to remove the sign? Or maybe if ag is pointing to the positive direction and the result of alfa*r is negative, just to remove the negative sign because ag is positive?
I think the vector method is in this case much more safe and if it is allowed to use in any situation I think it is better to use the vector method.
  • · Replies 17 ·
18K
