Exploring Silly Physics Questions: The Science Behind Tearing Paper and Hardness
  • Thread starter physikamateur
  • Tags
    Physics
In summary: Hardness is also related to heat because the harder an object is the more energy it takes to break it.
physikamateur
I know this might sound silly, but I always wonder what happens when you say, tear a paper. Do I actually rip the atoms of the paper ? If so wouldn't nuclear forces be rather weak ? The question also reminds me of hardness. What makes an object hard ? is it the arrangement of atoms ? or to be specific, the number of electrons which holds the atoms together ?
Sorry for the multiple-question post. I had a burst stream of consciousness.
Thank you.
Regards,
Alvin.
Paper is made up many interwoven 'fibers' of cellulose 'pulp'. Kind of like a t-shirt (but made of cellulose fibers).
The cellulose fibers are just long strings of molecules. When you rip paper, it's a mix of breaking the connections between the individual molecules and unraveling them at the same time.
You do not alter the atoms, you don't even alter the molecules.
What makes objects hard depends on how the atoms/molecules of a thing bind together. Some bind strongly and in crystalline lattices that support allot of force before being bent/broken. It all depends on how the atoms/molecules hook up and in what shape.
Not exactly, it does depend on packing or how well the molecules but most importantly what forces between molecules for example the force that holds molecules of hydrogen together are the weak van der walls attractions where you have unsymetric orbit of electrons causing one side of the molecule to be slightly negative and thus the other slightly positive and then these sides can attract to other molecules. Or you can have polar bonding where due to electro negativitys of atoms causing constant negative and positive sides of a molecule due to the fact that some atoms grab more electrons than others. Then you have the hydrogen bond witch is just a very strong polar bond and the strongest is covalent network like in dimond where their is just strong covalent bonding between atoms and it reapeats so dimond is just like one big molecule
1. What is the science behind tearing paper?
When we tear paper, we are actually breaking the weak bonds between the paper fibers. These fibers are made of long chains of cellulose molecules held together by hydrogen bonds. When we apply force, the fibers can no longer hold on to each other, causing the paper to tear.
2. Why does it become easier to tear paper along a straight line?
When we tear paper along a straight line, we are pulling the fibers in the same direction, making it easier for them to break. This is known as the principle of least resistance. On the other hand, tearing paper in a zigzag or irregular pattern requires the fibers to resist force in multiple directions, making it more difficult to tear.
3. Can we tear paper in space?
Yes, we can tear paper in space as long as there is enough force applied to overcome the bonds between the paper fibers. However, the lack of gravity in space can affect the way the paper tears, as there is no downward force to help guide the tear in a straight line.
4. How does paper hardness affect its tearability?
Paper hardness is determined by the amount of pressure applied during the papermaking process. Harder paper has more tightly packed fibers, making it more difficult to tear. On the other hand, softer paper has looser fibers, making it easier to tear.
5. Why do some materials tear more easily than others?
The tearability of a material depends on the strength of the bonds between its fibers. Materials with weaker bonds, such as paper, are easier to tear compared to materials with stronger bonds, such as metal. Additionally, the thickness and flexibility of the material can also affect its tearability.
9K
  • STEM Academic Advising
  • Quantum Interpretations and Foundations
  • Other Physics Topics
