Simple analog voice distortion circuit
  • Thread starter Thread starter fede.na
    Analog Circuit
The discussion revolves around building a simple analog voice distortion circuit without the use of integrated circuits (ICs). Participants explore various components and methods for achieving real-time voice distortion, including oscillators, analog multipliers, and RLC filters, with an emphasis on creating a robotic sound effect or other interesting distortions.
  • One participant proposes using a microphone, speaker, oscillators, analog multipliers, and RLC filters to create a portable, DC-powered voice distortion circuit.
  • Another participant suggests that a simple device using ring modulation might be effective for achieving the desired distortion.
  • A later reply mentions the possibility of creating a voice scrambler device using pseudorandom mixer carriers, drawing on the concept of voice inversion.
  • One participant reports success in building the modulator but encounters issues with audio separation between channels, noting that the expected sound quality changes based on how the audio signals are mixed.
  • Another participant speculates that incorrect connections of center-tapped windings might be causing the audio issues experienced by the builder.
Participants express varying opinions on the best approach to building the circuit, and there is no consensus on the cause of the audio issues reported by one participant. Multiple competing views on circuit design and functionality remain present.
The discussion includes assumptions about the availability of components and the builder's level of experience, which may affect the proposed solutions. There are unresolved technical details regarding the audio signal processing and the specific configurations of the circuit components.
Individuals interested in analog electronics, audio processing, and DIY circuit design may find this discussion relevant.
fede.na
Hi, I'm trying to build a simple analog voice distortion circuit, without any ICs if it's possible. It can get pretty hard to hunt down a specific IC around here.
Anyhow, my idea was to get a mic, a speaker, a few oscillators, analog multipliers and RLC filters to build a real time distortion (it will be a portable device, so it will be DC powered). I know it's probably too much to ask, but the original idea was that the distortion came out as kinda robotic, but it's not a must, any cool distortion will do it.
Can anyone point me in the right direction? I'm sort of the electrical engineering student with a lot of theoretical knowledge and little experience, so spare no explanations. Maybe just tell me a good waveform to multiply the input with and i'll search how to do it.. any help is appreciated. Pretty much everything I found involved an IC, so if I there's any chance I could avoid that, that'd be great.
Thanks!
Wow that was fast and very helpful, thank you very much nsaspook! I'll post how this turns out in case anyone is interested.
I hope you make something cool. With the proper circuits to generate pseudorandom mixer carriers you can even make a pretty good voice scrambler device that sounds similar to this:
ParkHill
Voice Inversion:
Simple inversion scrambler
Hi again! So I built the modulator and it works great... but there's something weird about it. I'm using my PC's stereo output to feed both the audio signal and the 30Hz carrier wave. The audio on the left channel and the 30Hz wave on the right channel.
I'm generating the signals in Audacity, but here's the weird thing: when I do a 100% separation of the tracks between channels, I can't hear almost anything. When I let a little bit of the carrier onto the other channel, it sounds a lot like it should... like youtube videos demonstrating the circuit. If I just go 50% both signals, i.e. not splitting the tracks at all between the channels, as if it were mono output I guess, it sounds perfect...
Why does this happen? It's really weird. I tried to contact the guy who made that tutorial but didn't find any contact info.
Thanks in advance
As a wild guess, maybe you have the center tapped windings connected incorrectly.
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 17 ·
