Simple centrifugal force problem
A user seeks help with a centrifugal force problem involving a 4m spinning tube and a 1kg projectile released at 1m from the axis. The discussion highlights the need to understand derivatives in practical applications, as the user struggles with theoretical concepts. Calculations reveal that the projectile's final speed upon leaving the tube combines radial and tangential components, resulting in a total speed of 2 m/s. The conversation also touches on the user's interest in solving varying mass rocket problems and requests additional practical problems involving derivatives. The thread emphasizes the importance of applying theoretical physics concepts to real-world scenarios.
antonio glez
simple centrifugal force problem please help
i have a 2m long tube spinning around its center at w=1
theres a 1 kg projectile at 1 m distance from the axe inside the tube that is released at a certain moment
what speed does the projectile have when it leaves the tube?
please show me how you do the calculations
welcome to pf!
hi antonio! welcome to pf! :smile:
(have an omega: ω :wink:)
hint: d2r/dt2 = … ? :smile:
hi tiny tim
im trying to get hold in the concept of derivative
the problem is that in the physics I am studying derivative is only treated in theoretical cases and not at all in practice
i can only understand practice, theoretics is too abstract for me
thats why i thought of this problem
but I am new to derivative still I am lost
im thinking also to solve a rocket of varying mass problem
so could you explain this problem to me please taking into account i hardly know derivation
also could you please point me to other practical probelms where there's derivatives or antiderivatives
thanks in advance :)
i know the object moves radially by the formula of centrifugal force so force = m*w*w*r
and being the mass =1 and f=m*a i know that force equals aceleration
so aceleration= m*w*w*r
but the radius is variable so i know its a derivative but i don't know how to apply it
thanks for your time :)
hi antonio! :smile:
that's right … acceleration = r
we can write that: dv/dt= r
to solve this, we use a trick: dv/dt = dv/dr dr/dt (that's the chain rule :wink:),
= v dv/dr (because dr/dt = v)
= d(v2/2)/dr …
so now your original equation can be rewritten = d(v2/2)/dr = r …
does that help? :smile:
If the tube is 2m long and spinning about its center, and the projectile is 1m from the axis, doesn't that put the projectile right at the very end of the tube to begin with?
oh yes i meant a 4 m long tube
thanks tiny tim with your help i obtained the radial velocity
but i understand that the final velocity is the resultant to the components of radial velocity and the velocity perpendicular to the radius that when the projectile lives the tube is 1*2=2
is this correct?
is this correct?
yes, the total speed will be the combination of those two perpendicular components, and yes the tangential speed is ωr = 1*2 = 2 :smile:
thanks I am on now solving a varying mass rocket problem , i don't have to do it but i like it :)
could you point me to more problems where i have to use derivative or antiderivatives please?
