Conservation of Energy in a Cart Falling from a Table
The discussion focuses on the conservation of energy in a scenario where a cart falls from a table. The key equations for energy conservation are presented, emphasizing the relationship between potential and kinetic energy. The main question revolves around how to handle horizontal and vertical velocities when calculating the cart's final kinetic energy just before it hits the ground. It is clarified that while both horizontal and vertical velocities can be considered, they should be treated separately, as only the vertical motion is influenced by acceleration due to gravity. The solution involves using conservation of energy without necessarily calculating the final vertical velocity.
GreenPrint
delta E = 0 = delta K + delta U
delta U = -delta K
mg(h - h_0) = m/2 (v_0^2 - v^2)
or in its common form
mgh - mgh_0 = (m v_0^2)/2 -(m v^2)/2
mgh + (m v^2)/2 = (m v_0^2)/2 + mgh_0
which is how msot people perfer to memorize very simple intro to physics conservation of energy equations but I prefer this formula as it is more sipmle
now my question is velocity conserved in the following situation
a cart is riding on a horizontal surface I know the velocity right before it leavs the horizontal surface and fall to the floor
now this velocity is a horizontal velocity right so let's let this equal the velocity naught ok but the thing is that the final velocity will be equal to the velocity naught, except not really becasue of drag force but that's not a topic of AP physics B, so the horizontal velocity is the only velocity that changes but in this case there would be a final velocity but the velocity naught in the y direction would be zero because it only has a initial horizontal velocity...
Like I'm trying to solve this problem and can't becasue I think in order to do so I have to use both a horizontal velocity for the inital right before the cart which is perfectly fine but then I have to solve for the final vertical velocity in order to solve for the kinetic energy right before it reachs the ground which I don't like one bit
how can i mix and match horizontal velocities and vertical velocities whenever I want...
Heres the problem
[PLAIN]http://img338.imageshack.us/img338/9841/physics1.jpg
heres the scoring guidelines for (d) which I need help with
[PLAIN]http://img401.imageshack.us/img401/6328/physics2.jpg
Once you've calculated the speed of the cart as it leaves the table, all you need (for part d) is conservation of energy. You don't need to solve for the final vertical velocity, although it's perfectly fine if you do (just more work). In projectile motion, treat horizontal and vertical motion separately, since only the vertical is accelerated.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
