Simple difference quotient question. Function -> simplify answer
The discussion centers around understanding how to evaluate the difference quotient for the function f(x) = 4 + 3x - x^2. Participants clarify that the problem requires finding f'(3) using the limit definition of the derivative. To do this, one must substitute 3+h into the function, leading to the expression f(3+h) = 4 + 3(3+h) - (3+h)^2. The key step involves expanding this expression and simplifying it to find the derivative. Understanding the role of the dummy variable in function evaluation is crucial for solving the problem correctly.
nukeman
Simple difference quotient question. Function --> simplify answer
I just don't understand this question! Here, I will take a picture of it. Can someone please explain how I answer these? Or even show me a website that shows how to do these? Its not in my review book.
QUESTION is in ATTACHMENTS!
It seems pretty straightforward what the question is asking. What specifically don't you understand?
Can you tell me the first step? When you look at this, what is the first thing you see/do?
Exactly what the problem statement says: evaluate the difference quotient. If you don't understand what that means, try looking up "difference quotient" in your book.
Must be missing something here.
I would plug in the f(x) values to the 2nd function, but there is no x's, just h ? How do I plug in values?
The problem is asking you to evaluate the difference quotient to find f'(3).
wow I'm lost. :(
Dude, f(x) = f(3+h) if x = 3+h
nukeman said:
wow I'm lost. :(
The difference quotient to find the derivative of a function, f'(x), looks like this:
$$ f'(x) = \lim_{h \to 0} \frac{f(x + h) - f(x)}{h}$$
The difference quotient to find the derivative of a function at a specific number a, f'(a), looks like this:
$$ f'(a) = \lim_{h \to 0} \frac{f(a + h) - f(a)}{h}$$
Do you recognize that your problem is asking for f'(3)?
Here's the image:
So, if f(x)=4+3x-x^2\,, then what is f(3+h)\ ?
SammyS said:
Here's the image:
SammyS, that is the one part I am having trouble fully understanding...
It would have helped if you could have said that right from the beginning.
In f(x)=4+3x-x2, the x is what's called a dummy variable. Anything you put in the lefthand side where the x is shows up wherever the x appears on the righthand side. For example, suppose you have g(x) = 2x+4. Then
\begin{align*}
g(y) = 2y+4 \\
g(h+3) = 2(h+3)+4 \\
g(4z) = 2(4z)+4 \\
g(weasel) = 2(weasel)+4 \\
g(3) = 2(3)+4 = 10
\end{align*}
Now tell us what you think f(3+h) is equal to in your problem.
Apparently you don't understand how to evaluate a function's formula.
If g(t) = 3 - t2 (for example)
then g(1) = 3 - (1)2 = 3 - 1 = 2
and g(5) = 3 - (5)2 = 3 - 25 = -23
and g(a + 2) = 3 - (a + 2)2
So for your function, what is f(3 + h)?
"So for your function, what is f(3 + h)?"
f(3+h) = 4 + 3(3+h) - (3+h)^2 ?
Yes. You'll need to expand the right side and collect common terms.
Yup, that's it.
  • · Replies 25 ·
