Calculating Q for Cylinder with Inhomogeneous E Field
In summary, the conversation discussed a simple electrostatics problem involving a cylinder with an inhomogeneous electric field. The goal was to calculate the charge of a piece of the cylinder using Gauss' law in both integral and differential form. However, there was a discrepancy in the results, which was ultimately attributed to a mistake in the form of the divergence in cylindrical coordinates. The correct form should be (d/dr+1/r)E_r, resulting in a factor of 4 instead of 3 in the calculation of Q.
jacobrhcp
169
[SOLVED] simple electrostatics problem
a cylinder, the inhomogenous E field is given by [tex] E = E_{0} (\frac{r}{R})^{3} [/tex]
the assignment was to calculate Q of a piece of the cylinder of length L in two different ways, by gauss law in integral form and in differential form
[tex]\oint E dA = \frac{Q}{e_{0}}[/tex]
so [tex]Q = 2\pi e_{0} L E_{0} R[/tex]
the other way around, [tex]\nabla E = \frac{\rho}{e_{0}}[/tex]
so [tex] \rho = e_{0} E_{0} 3 \frac{r^{2}}{R^{3}} [/tex]
so [tex] Q = e_{0} E_{0} 3 \oint \frac{r^{2}}{R^{3}} r dr d\theta dl = 2 \pi e_{0} E_{0} \frac{3}{4} L R [/tex]
which is a factor 3/4 different from my other expression for Q
where did I go wrong?
Review the form of the divergence in cylindrical coordinates. The non-vanishing term is (d/dr+1/r)E_r. That changes your '3' in rho to a '4'.
1. What is an electrostatics problem?
An electrostatics problem is a type of problem in which the behavior of electric charges at rest is studied. It involves the application of the laws of electrostatics, such as Coulomb's Law, to determine the distribution of charges, electric fields, and potential in a given system.
2. How do you solve a simple electrostatics problem?
To solve a simple electrostatics problem, you first need to identify the relevant information, such as the charges and distances involved. Then, you can use Coulomb's Law and other relevant equations to calculate the electric field, potential, and other quantities. It is important to set up the problem correctly and pay attention to units.
3. What are some common applications of electrostatics?
Electrostatics has various applications in our daily lives, such as in the functioning of electronic devices, air purifiers, electrostatic precipitators, and inkjet printers. It is also essential in understanding lightning, the Van de Graaff generator, and the behavior of charged particles in space.
4. What is the difference between conductors and insulators in electrostatics?
Conductors are materials that allow the free flow of electric charges, while insulators are materials that resist the flow of charges. In electrostatics, conductors have more free electrons, making them easier to charge and discharge, while insulators have tightly bound electrons, making them harder to charge or discharge.
5. What is an electric dipole?
An electric dipole is a pair of equal and opposite charges separated by a distance. It can be created by two opposite charges or by shifting the center of positive and negative charges in a neutral object. Electric dipoles have a dipole moment, which is a measure of the strength and direction of the dipole.
