Time Dependent Semi-Major & Semi-Minor Axes in Ellipse Equation
  • Thread starter Thread starter WannabeNewton
    Ellipse
The discussion centers on whether the semi-major and semi-minor axes of an ellipse can be time-dependent in the standard ellipse equation. It clarifies that while the original equation presented does not represent a time-dependent ellipse, it is possible to create one by defining the axes as functions of time. An example of a time-dependent ellipse is given as \frac{x^2}{(a(t))^2}+ \frac{y^2}{(b(t))^2}= 1. The conversation concludes with the realization that the initial setup could be adjusted to incorporate time variance correctly. Ultimately, the concept of time-dependent axes in ellipse equations is affirmed as valid with proper formulation.
WannabeNewton
Can the semi - major and semi - minor axes of an ellipse be time dependent? More specifically, can you have time dependent semi - major and semi - minor axes present in the standard form of the ellipse? I have an equation of the form \frac{(\xi ^{1}(t))^{2} }{a^{2}} + \frac{(\xi ^{2}(t))^{2}}{b^{2}} = 1 where \xi ^{\alpha } are components of a separation vector, a^{2} = [2 + \frac{1}{2}sin^{2}\omega t](\xi ^{1}(0))^{2}, and b^{2} = [2 + \frac{1}{2}sin^{2}\omega t](\xi ^{2}(0))^{2} but I don't know if the standard form can actually have time dependent semi - major and minor axes.
Mathematics news on Phys.org
Yes, of course. However what you are writing does NOT.
\frac{\xi^1(t))^2}{a^2}+ \frac{\xi^2(t))^2}{b^2}= 1
is a single ellipse with axes of length a and b for all t. If t is "time", this could be interpreted as an object moving around that fixed ellipse with changing speed.
An ellipse with "time dependent sem- major and minor axes" would be
You can add "time dependence" or dependence on any other variable at will, just by making some parameters function of that variable.
So if in the original equation, If I had the usual X and Y instead of the time dependent separation vector but with the same form of the semi - major and minor axes that I posted above then it would be allowed? Thanks for the reply.
EDIT: Never mind I get what you are saying. I think I should have had the initial coordinate separations on the top and the time variance of the separation plus the sin terms on the bottom.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
