Simple equation solving (I think)
  • Thread starter Thread starter tachu101
To find the x-intercepts of the function f(x) = ln(x+1) - (sinx)^2, the equation can be simplified to ln(x+1) = (sinx)^2. It is noted that there are three x-intercepts, with x = 0 being the most apparent. Analyzing the maximum and minimum values of sin^2(x) helps establish a range of x-values where x-intercepts may exist. Graphing f(x) within this domain allows for estimation of the x-intercepts. While Newton's method can refine these estimates, it may be considered complex for a pre-calculus level.
tachu101
Find x-intercepts of f(x)= ln(x+1)-(sinx)^2
I know to get to ln(x+1)=(sinx)^2 but have no idea what to do after that.
I don't think it's THAT easy, x = 0 comes to mind though
It turns out that there are 3 x-intercepts (x=0 is the obvious one). You can estimate what domain they lie in by looking at the maximum and minimum values of \sin^2(x)...what are those? What does that tell you about the max/min of \ln(1+x) for which there might be any x-intercepts? You can use that to determine a range of x-values for which x-intercepts are possible.
The next step would be to graph f(x) over that Domain and estimate value for the x-intercepts.
If you are familiar with Newton's method, you can improve your estimations through a few iterative calculations.
This seems to be kind of an overkill for someone in pre-calc though unless you were allowed to use a CAS.
Use iteration?
Yes you could use Newton's as was mentioned but I still maintain it's a somewhat hard problem for pre-calc then again I never took pre-calc and maintain that it's a useless class :)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
