Simple equation to show work done on an equipotential surface is zero
negation
w = ΔKE + ΔPE
For a particle moving at constant speed, there is no change in velocity so no change in KE. What about change in PE for a partcile moving at constant speed on a equipotential surface? Would I be right in stating that since the particle moves along the same surface (AKA same height), there is no change in height and therefore no change in PE?
Mathematics news on Phys.org
Yes.You are correct.
I don't think I would phrase it in terms of "height". There are many ways of having potential energy that have nothing to do with height. As long as the object is moving on an "equipotential surface", its potential energy doesn't change- by definition of "equipotential".
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
