Solving the Graph of Equation (y^2)=a(x^2): True Statement?
  • Thread starter ritwik06
In summary: If I read the question again, it says that a is "positive constant". Are you stressing on the point that the squares of a negative number is always positive??No, I'm not stressing on that point. What do you mean by "positive constant"?
ritwik06
580
For the graph of equation (y^2)=a(x^2), where a is a positive constant, whic of the following is true?
1) y increases linearly with x
2) y increases as the square of x
3) y increases as y^1/2
4) If x increases, y can increase or decrease.
y is directly proportional to x. as a is a constant, the first option would be right!
Is my approach right?
Not all, I'm afraid. Rewrite your equation as:
[tex](y-(\sqrt{a})x)(y+(\sqrt{a})x)=0[/tex]
Now, two questions:
1. Why is this rewriting permissible?
2. What must you conclude from it?
Now, two questions:
Ans 1 because the difference of two squares can be factorised as suc:
a^2-b^2=(a+b)(a-b)
Ans 2. I don't know what can be concluded! Please be clear!
Well, if two numbers multiplied together is zero, what can we say about those numbers?
That anyone of them is equal to zero or both are zero.
So,
EITHER:
[tex]y=\sqrt{a}x[/tex]
OR
[tex]y=-\sqrt{a}x[/tex]
Given that knowledge, which statement is true?
arildno said:
So,
EITHER:
OR
The fourth option? :approve:
Yup :smile:
arildno said:
Yup :smile:
but sir. I agree totally with you. But if you look at it straight away, it seems that y is directly proprtional to x. hence they will have a linear relationship. How will you criticize this point? Thanks for the effort! :approve:
Three flaws:
1. As for direct proportionality (i.e, ratio constant), remember that the proportionality constant in such a relation can be positive or negative, so that from mere direct proportionality, you cannot conclude that y will increase with x, it could equally well decrease with x.
2. If we assume that the y-coordinate is to be regarded as a FUNCTION of the x-coordinate (so that we limit ourselves to only a part of the permissible solution pairs of the original equation), we might have a discontinuous function relationship in that in one x-region, the function values followed the upper line, and in an adjoining x-region, the function values follow the lower line.
In this case, we see that the ratio x/y is NOT constant, that is direct proportionality do not hold between x and y
3. There is no reason why we should assume that there exist any function relating x-values to y-values. Indeed, the solution set to the equation do not permit a function construction in general.
To be sure, if we limit ourselves to just a part of the solution set, then we may, indeed, have some functional relation between the picked (x,y)-values.
But that is a totally different issue.
This is really only echoing arildno but:
I would "criticise" that point by saying "Yes, it true- but off the point." The answer did not say "linearly related", it said "increases linearly". That was arildno's point.
arildno said:
Three flaws:
Whats the difference between "inearly related" and "increases linearly"?
Yes, and so with y2= ax2 we can have either
[itex]y= \sqrt{a}x[/itex] or [itex]y= -\sqrt{a}x[/itex]
In both [itex]y= \sqrt{a}x[/itex] and [itex]y= -\sqrt{a}x[/itex] y and x are "linearly related". In the first, y "increases linearly" with x but in the second y "decreases linearly" with x.
Thanks a lot for the efforts. o:)
What is the equation for solving the graph of (y^2)=a(x^2)?
The equation is (y^2)=a(x^2), where a is a constant.
How do you graph (y^2)=a(x^2)?
To graph (y^2)=a(x^2), you can use a table of values to plug in different values for x and solve for y. You can also use a graphing calculator to plot the points and connect them to create a curve.
What does the graph of (y^2)=a(x^2) look like?
The graph is a parabola that opens in either the positive or negative direction, depending on the value of a. If a is positive, the parabola opens in the same direction as a regular parabola. If a is negative, the parabola opens in the opposite direction.
What is the significance of a in the equation (y^2)=a(x^2)?
The value of a determines the shape and orientation of the parabola. A larger absolute value of a will result in a narrower and taller parabola, while a smaller absolute value of a will result in a wider and shorter parabola.
Can the equation (y^2)=a(x^2) have multiple solutions?
Yes, the equation can have multiple solutions. Each value of a will result in a different parabola, and each parabola will have two solutions for y for every value of x.
  • Precalculus Mathematics Homework Help
