Simple Harmonic Motion of a Bent Rod
The discussion focuses on determining the angular frequency of a bent rod undergoing simple harmonic motion when displaced from equilibrium. The rod, with mass m and length 2L, is bent at its midpoint, forming an angle α between its two segments. Key equations include the torque due to gravity and the moment of inertia, which is calculated as ML²/4. The participants emphasize the importance of applying Newton's second law for rotations to derive the second-order differential equation necessary for solving the angular frequency.
  • Understanding of simple harmonic motion principles
  • Familiarity with Newton's second law for rotational dynamics
  • Knowledge of torque and moment of inertia calculations
  • Ability to analyze forces acting on a rigid body
  • Study the derivation of angular frequency for simple harmonic oscillators
  • Learn about the calculation of torque in rotational systems
  • Explore the concept of center of mass in composite bodies
  • Review the moment of inertia for various geometries, particularly rods
Physics students, mechanical engineers, and anyone interested in the dynamics of oscillating systems will benefit from this discussion.
HelpMeJebus
A uniform rod of mass m and length 2L is bent into 2 straight segments about its
midpoint. The angle between the 2 segments is α. The bent rod is balanced on a sharp
fulcrum. Find the angular frequency for small oscillations if the rod is displaced from
equilibrium and released.
know total mass of rod: m
length: 2L
angle between rods is: alpha
x(t)=A cos((omega)(t)+(phi))
ma=??
I've tried to draw a diagram explaining the motion, and forces involved and I can tell that the "tension" or force that the rod applies at the center of mass of each length of the rod is responsible for the restoring force, however I am not sure how to treat this in order to write Newton's second law so that I can solve the 2nd order differential equation for the angular frequency. Help is greatly appreciated!
Gravity supplies the restoring force.
What torque does gravity exert about the pivot? What's the rotational inertia about the pivot?
Aha, another one of these rotational problems. I thought I had escaped them.
Gravity does indeed supply the restoring force and I fell into the same old physics student trap.
Approaching this with Newton's second law for rotations, we get the sum of all the external torques= (Moment of Inertia)*(Angular Acceleration).
I am aware that torque is: R (vector) X Force (vector), but I am still unsure as to how to label the angles. Let's say we displace it a small angle theta, I am unsure how to treat this. Qualitatively it is easy to see that the torque will be greater for the "upper" end of the bent rod when it is displaced, because the angle between the weight and the "lower" part of the rod is approaching parallel, but I am not sure how to notate this in quantitative terms.
As for the moment of inertia, it is the sum of all of the individual mass particles and their radius from the axis of rotation squared. In this case I believe it would be ML^2/4. Now all I need is a way to represent those torques...
(I)(d^2 (theta/dt) +??(theta)=0, where the ??'s actually give me the square of the angular velocity.
Thanks for the quick, and very helpful response!
For the purpose of calculating the torque, realize that gravity can be considered to act at the center of mass of the bent rod. Find the center of mass and its distance from the pivot.
How did you arrive at this value? Hint: What's the moment of inertia of a single rod about one end?
  • · Replies 34 ·
