Simple integration problem not covered in textbook
4 replies · 2K views · last reply
karush
MHB
I know this is a simple problem but new at it. answer not in book so hope correct.
Re: expanding cube
You have the formula for volume:
$$V=s^3$$
Differentiating with respect to time $t$, we find:
$$\frac{dV}{dt}=3s^2\frac{ds}{dt}$$
Now plug in the given data...and keep in mind your units...you should get $$\frac{\text{cm}^3}{\text{s}}$$
Re: expanding cube
$$3\cdot 2^2 \cdot 6 = 72 \text { cm}^3\text{/ sec}$$
and
$$3\cdot 10^2 \cdot 6 = 1800 \text { cm}^3\text{/ sec}$$
Re: expanding cube
and
Looks good. If you wish to be absolutely clear on an exam, I would write (in addition to showing your differentiation with respect to $t$ to obtain the formula):
a) $$\left. \frac{dV}{dt} \right|_{s=2\text{ cm}}=3\left(2\text{ cm} \right)^2\left(6\,\frac{\text{cm}}{\text{s}} \right)=72\,\frac{\text{cm}^3}{\text{s}}$$
b) $$\left. \frac{dV}{dt} \right|_{s=10\text{ cm}}=3\left(10\text{ cm} \right)^2\left(6\,\frac{\text{cm}}{\text{s}} \right)=1800\,\frac{\text{cm}^3}{\text{s}}$$
Re: expanding cube
makes sense
I will post some more to see how close I am
