How Do You Prove a = 4R/sqrt(3) in a Body-Centered Cubic Structure?
  • Thread starter krnhseya
  • Tags
    Geometry
In summary, when trying to calculate the diagnal edge of a face of a cube, using one side to find the edge and forming a triangle with the other side and the square root of 2, something is wrong and the solution uses the Pythagorean theorem instead.
krnhseya
103
This is for body-centered cubic crystal structure.
Prove a = 4R/sqrt(3). R is the radius of sphere and a is the edge of the cell (cubic).
The image attached will be cut into cube so that 4 outter spheres' centers will be the edges of the cube, a.
n/a
Well, the disagnal from the farthest two points are 4R.
I tried to use one face to calculate the diagnal edge of the face and form a triangle with 4R and sqrt(2) but it won't work.
Something is wrong...please help!
Look at it this way, you've got the find the length of the cube diagonal which you know to be 4R. To find the cube diagonal you just have to apply pythagoras theorem twice. Firstly to find the base square diagonal, which you should get as sqrt(2). Then you find the cube diagonal using the base square diagonal and the height of the cube. Then just equate the 2 expressions.
Your image hasn't been approved yet so this is all I can say.
n/a
[itex]\sqrt{2}[/itex]? No, of course that won't work. Were did you get [itex]\sqrt{2}[/itex]? Perhaps you were thinking that the diagonals of a square, of side length a, have diagonal length [itex]a\sqrt{2}[/itex]. But here you are dealing with a cube. To find the length of a diagonal, you have to apply the Pythagorean theorem again. The length of the diagonal from bottom vertex to the opposite bottom vertex is the length of the diagonal of one face, a square: [itex]a\sqrt{2}[/itex]. But now you have a right triangle with base leg of lenth [itex]a\sqrt{2}[/itex] and vertical leg (up to the opposite point of the cube) of length s. By the Pythagorean theorem, the diagonal length is [itex]\sqrt{2a^2+ a^2}= a\sqrt{3}[/itex].
Use that instead.
Wow...I've been thinking that a*sqrt(2) was hypotenuse...
I apologize for such a thread.
Thank you very much.
Related to How Do You Prove a = 4R/sqrt(3) in a Body-Centered Cubic Structure?
1. What is geometry?
Geometry is a branch of mathematics that focuses on studying the properties and relationships of shapes, sizes, positions, and dimensions of objects in space.
2. What are the basic concepts in geometry?
The basic concepts in geometry include points, lines, angles, planes, and shapes such as circles, triangles, squares, and rectangles.
3. What are the different types of angles in geometry?
The different types of angles in geometry include acute angles (less than 90 degrees), obtuse angles (greater than 90 degrees), right angles (exactly 90 degrees), and straight angles (exactly 180 degrees).
4. How do you find the area of a shape in geometry?
The area of a shape in geometry is found by multiplying the length of its base by its height. The specific formula used depends on the type of shape, such as A = bh for rectangles and A = ½bh for triangles.
5. How is geometry used in real life?
Geometry is used in various fields such as architecture, engineering, design, and navigation. It is also helpful in everyday tasks such as measuring and drawing shapes, understanding maps, and calculating distances.
  • Atomic and Condensed Matter
16K
16K
  • Classical Physics
11K
13K
