Period of Oscillation of Pendulum Varies with Amplitude
The discussion revolves around determining the period of oscillations of a simple pendulum as a function of amplitude. Participants explore the energy expressions for the pendulum, focusing on kinetic and potential energy, and clarify that potential energy is maximized when the pendulum is at its highest point. There is confusion regarding the use of derivatives in calculating kinetic energy, with some participants emphasizing that standard formulas can be used instead. The importance of understanding the difference in potential energy is highlighted, and the conversation touches on the interpretation of energy values in relation to the pendulum's motion. Overall, the thread illustrates the complexities of applying energy concepts in pendulum dynamics.
armis
Determine the period of oscillations of a simple pendulum ( a particle of mass m suspended by a string of length l in a gravitational field) as a function of the amplitude of oscillations.
T(E) = \sqrt(2m) \int^{x_2(E)}_{x_1(E)}\frac{dx}{\sqrt(E-U(x)}
where T is the period of oscillations
I only need the expression of E(x) and the problem is pretty much solved but I can't figure out why (which is rather embarassing :frown:) the energy of the pendulum
E = \frac{1}{2}ml^2{\phi}^2 - mgl\cos{\phi} = -mgl\cos{\phi_o}
where \phi is the angle between the string and the vertical and \phi_0 the maximum value of \phi
Any hints?
thanks
Hi armis! :smile:
KE + PE = constant. So …
Hint: at what angle does KE = 0? :smile:
Hi Tiny-tim :smile:
Yeah, I knew that! At least that... :smile:
KE is equal to zero at maximum value of \phi, isn't it? And the velocity is highest at point where \phi is zero thus the kinetic energy has the highest value as well.
Let's see:
x= l\sdot\sin{\phi}
y= l\sdot\cos{\phi}
let's assume l doesn't change ( metal or something). Then
\frac{dx}{dt}= l\sdot\cos{\phi}
\frac{dy}{dt}=-l\sdot\sin{\phi}
Thus KE=\frac{ml^2}{2} :confused: Which is totally ridicilous... It must depend on time! Where did I go wrong?
After staring at my post for a while I realized that \phi actually does depend on time. Thus I forgot the derrivative of \phi ( correct me if my termionology is wrong please)
Oh, my godness... I am so terrible at this :smile:
Actually in the scanned copy of the book the answer part is scanned so badly that one can't see the dot sign above \phi. I was more focused on how to get \phi in there...:rolleyes:I guess I should look the answers less and focus on the problem instead, that's for sure :approve:
But I still can't get the second part right
Hi armis! :smile:
I think you need some sleep … :zzz:
You don't need derivatives at all …
lcosφ - lcosφo is the difference in height (for working out the PE). :smile:
I certainly do :smile: but I fell in love in physics just yesterday and just can't stop. This book by Landau by the way from which the exercise is taken is brilliant
Hmm, why? If
x=l\sin{\phi}
y=l\cos{\phi}
then
\frac{dx}{dt}=l\sin{\phi}\frac{d\phi}{dt}
\frac{dy}{dt}=-l\cos{\phi}\frac{d\phi}{dt}
thus
KE=\frac{m}{2}({\frac{dx}{dt}}^2+{\frac{dy}{dt}}^2)=\frac{m}{2}l^2(\frac{d\phi}{dt})^2
which is exactly what is given as the answer or I am completely wrong. How can I do that without derivatives? :confused:
I understand what you mean but I am still confused :blushing:
By the way in their given formula if I understand correctly the part -mg\cos{\phi} is PE. Now since \phi is the angle between the string and the vertical then once \phi is 0 then the potential energy has the highest value? I just can't get it. Isn't it supposed to be 0 at \phi=0?
:cry:
Hi armis,
You don't need derivatives to figure out your energy formula because you can use the standard formulas for kinetic and potential energies. What are those formulas?
:cry:
When \phi is 0, the magnitude of that term ( -mg\ell \cos{\phi}) [/tex] is a maximum, but since it is negative, the potential energy will have it&#039;s smallest (most negative) value of the motion.<br /> <br /> You don&#039;t need the potential energy to have a specific value of 0 at any particular point, because all that matters is the difference in energy between two points.
Hi Alphysicist :smile:
Well
KE = \sum_j^s \frac {m}{2} ( \frac {dq_j}{dt} )^2
where q are the generalised coordinates and s are the degrees of freedom.
And if the force is conservative as it is here then
F = - \nabla PE(q) thus in this case PE=-Fr
That's as standart as I could figure it out :frown:
As for the difference in PE:
- mg\triangle{h} = - mg ( l\cos{\phi} - l\cos{\phi_0} )
Is this correct?
thanks
Well
That's right; and so by knowing that in this problem only the angular coordinate is changing with time you can just write down the kinetic energy term.
Is this correct?
thanks
Yes, so the potential energy at any particular point you want is given by that formula:
and remember that you can add any constant value you like to the potential energy; so to simplify add the constant -m g l \cos\phi_0 to that and you'll get the original energy formula.
Hi armis! :smile:
I know you've got it now, but let's just clarify what you did here:
armis said:
Hmm, why? If
x=l\sin{\phi}
y=l\cos{\phi}
then
thus
As you say, that's the correct formula for the KE.
(Though you could have used the formula for converting angular velocity to speed: v = \omega r.)
But the formula without derivatives gave you the PE! :smile:
One question though. If I choose the generalised coordinate as \phi and l then I will not arrive at the KE formula I did previously. What am I missing?
That's still a little bit confusing but I am getting there. At least by now I already understand that all what matters is the difference in potential energy but I still didn't figure the physical interpretation of this :redface:
!Exactly... :rolleyes: This is harder than I thought but I have learned a lot so far. Thanks for your help
By the way I am free to book suggestions on classical mechanics as by now it's rather clear I should read one. Landau is a pretty tough one
The specific formula you entered
where m is the mass, is not true when the generalized coordinate does not have units of length. If you want to use \phi as your coordinate, then you will end up with the rotational kinetic energy formula (1/2) I \dot\phi^2. Since l is not changing with time it does not have a kinetic energy term.
The alternative, which I would do, is to follow tiny-tim's good advice about using v=r\dot\phi in the kinetic energy formula (1/2) m v^2
The potential energy function here is mgh. By adding the constant mentioned earlier, h is the vertical position relative to the center of the circular path (so that h=0 when the string is horizontal).
Oh, I see. Thanks a lot!
  • · Replies 16 ·
  • · Replies 27 ·
