Balloon Experiment: Exploring Newton's Third Law of Motion
In summary, the smaller balloon shrank at the expense of the larger balloon expanding. This has something to do with Newtons third law, for every action there is an equal and opposite reaction.
Khaled332
I was required to blow up two identical balloons, one more than the other. Then I joined the two balloons via a short length of tubing and watched as the smaller balloon began to shrink at the expense of the larger balloon expanding. I was thinking that this had something to do with Newtons third law, for every action there is an equal and opposite reaction, but I am sure it is much more in depth, thanks
Interesting. I would have expected the smaller balloon to expand until both balloons equalized at the same size.
That is an unexpected result. I would expect the larger balloon to be under higher pressure and force air into the smaller balloon until they were equal.
Since you stated that the opposite happened I will put forward a theory. Perhaps the larger balloon was inflated to the point that the rubber was permanently stretched and therefore lost some tension as compared to the less inflated balloon with undamaged rubber. You could test this theory by inflating 2 new balloons to the larger size, then partially deflating one before connecting them. This should ensure that the rubber of both balloons has been stretched beyond its elastic limit.
Surprised as well, but it makes sense in retrospect. If we say E~A, V~R³, A~R², and P=dE/dV, then P~1/R.
Nothing to do with Newton's 3rd, though.
Edit: And come to think of it, it also agrees with experience of inflating balloons. It's always the hardest to get it going, but once it expands a little, inflating it further becomes easier. So the above dimensional analysis appears to be correct.
The pressure in a balloon is not just simply proportional to the amount of air in it so the experiment is not a simple one as with joining two columns of water with a pipe (which would just balance out). Our memory tells us that, when a balloon is only partially inflated, it is actually quite hard to blow up (stiff) and it gets easier, once it is really stretching. Finally, it gets more difficult to inflate when it's almost at its maximum size. The Stress / Strain (Pressure / Volume, actually) curve is S shaped and the stiffness changes as the shape changes.
If you were to join two balloons which were both 'well inflated', I think you would get a stable situation where the smaller one would inflate and the larger one would deflate until equilibrium was reached. That is because they would both be operating in the same region of their pressure / volume curve.
I'm myself astonished about what you said. Never thought something like that could actually happen.
But what Sophiecentaur mentioned could make sense.
What tubing did you use ? I want to try it myself.
Remember that the characteristics of bubbles are different so how they would behave would be different from balloons.
The pressure inside a bubble is inversely proportional to the radius of the bubble so the smaller radius bubble will inflate the larger radius bubble.
Rubber is a polymer and displays "hysteresis" one characteristic being that as the balloon inflates and the polymer chains straighten the balloon becomes stiffer.The pressure inside the balloon should then rise much more steeply due to the volume increase of the balloon tending to level off.If I am right about this a balloon which is inflated "hard"(near to bursting)should initially inflate a balloon of the same structure which is inflated "soft" and which has a smaller radius.If I can get some balloons I will try it out.
FAQ: Balloon Experiment: Exploring Newton's Third Law of Motion
1. What materials do I need for a simple physics experiment?
To conduct a simple physics experiment, you will typically need materials such as a ruler, a stopwatch, a scale, various objects of different weights, and potentially other household items depending on the specific experiment you are conducting.
2. How do I set up and conduct a simple physics experiment?
To set up and conduct a simple physics experiment, you will need to follow a specific procedure or set of steps that are outlined in the experiment's instructions. This may involve measuring and recording data, manipulating variables, and observing the outcomes of the experiment.
3. What are some examples of simple physics experiments?
Some examples of simple physics experiments include testing the effects of gravity on objects of different weights, measuring the speed of a rolling object, or exploring the properties of static electricity. There are many websites and resources available that provide ideas and instructions for simple physics experiments.
4. What safety precautions should I take when conducting a simple physics experiment?
When conducting any experiment, including simple physics experiments, it is important to prioritize safety. This may involve wearing protective gear, working in a well-ventilated area, and handling materials and equipment with caution. Always follow the safety guidelines and instructions provided for each experiment.
5. What can I learn from conducting a simple physics experiment?
By conducting a simple physics experiment, you can learn about the fundamental principles of physics and how they apply to the world around us. You can also improve your critical thinking and problem-solving skills, as well as your ability to conduct experiments and analyze data. Additionally, you may gain a better understanding and appreciation for the scientific method and the process of experimentation.
