Estimating the Diameter of the Moon Using a Pencil - Simple Physics Problem
  • Thread starter Thread starter k_yup
To estimate the diameter of the Moon using a pencil, hold the pencil at a distance of about 15 cm from your eye, ensuring its end blocks the Moon. Measure the pencil's diameter, approximately 1.5 cm or 1.5x10^-5 km. Use similar triangle theory to relate the pencil's size and distance to the Moon's size and its distance from Earth, which is 3.8x10^5 km. This method allows for a straightforward calculation of the Moon's diameter based on the measurements taken. This approach effectively combines basic geometry with practical observation.
k_yup
im new to the physics world and know this is probably an easy problem but i don't know where to start
Hold a pencil in front of your eye at a position where its end just blocks out the moon. Make approprite measurements to estimate the diameter of the moon, given that the earth-moon distance is 3.8x10^5km.
i figured that you prob had to measure the end of a pencil which i measured about 1.5 cm which is 1.5x10^-5km but i don't really know what to do from there.
How far away was the pencil from your eye?
about 15cm
so use simular triangle theory?
Yes, that would do it nicely.
Sorry for late reply I guess I missed it last night when I scanned the board.
Good luck.
