Simple proof of inequality by induction
naele
Prove 2n+1< 2^n for n=3,4,...
<br /> P(3)= 6+1&lt;2^3<br />
The base case holds, now assume true for P(k). Now consider P(k+1)
<br /> 2(k+1) +1 = 2k+3
<br /> 2^{k+1} = 2^k \cdot 2<br />
So this is where I get stuck, I don't quite know how to finish the proof. As can be seen, the difference between the two sides of the inequality in P(k+1) is that the LHS has 2 added, while the RHS is multiplied by 2. Would it be sufficient to observe that in the base case, adding 2 to the LHS and multiplying the RHS by 2 still maintains the inequality and so necessarily it should hold for any larger n?
2(k+1) +1 = 2k+3 = (2k+1) + 1
2^{k+1} = 2.2^k
so starting with the case for n
2n+1<2n
add 2 to both sides
2(n+1)+1<2n+2
with one more step to show the case for n+1
Well, it should be possible to show that 2^k+2&lt;2^k \cdot 2 for some k greater than whatever.
2&lt; 2\cdot 2^k - 2^k
2&lt; (2-1)2^k
2&lt;2^k. From here take the log of both sides, and it shows that 2^k +2 &lt; 2^{k+1} holds for all k > 1, which is fine because we're only considering from n=3. So since that's the case and 2(n+1)+1 &lt; 2^n +2 &lt; 2^{n+1} this should complete the proof?
i think that does it, but if you're happy upto
2(n+1)+1<2n+2
then just using, that for n>1
2<2n
should pretty much complete above
ps. i think itspretty much the same reasoning, though just a little clearer in order
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
