Mechanical Advantage: Pulley Systems & Archimedes' Ship
  • Thread starter Thread starter BogMonkey
    Pulley Systems
Mechanical advantage in pulley systems allows a smaller input force to lift heavier loads, exemplified by a system that provides a mechanical advantage of 4. When applying a 20N force to lift an 80N block, the additional force comes from the system's configuration, which distributes the load across multiple strands of rope. This principle is akin to leverage, where a small movement can produce a larger effect, similar to how gears and levers function. Archimedes famously demonstrated this concept by moving a ship using pulleys, showcasing the power of mechanical advantage in practical applications. Understanding these mechanics reveals how pulleys condense motion, enabling significant lifting capabilities with minimal effort.
BogMonkey
I'm fairly fascinated by the idea of mechanical advantage using pulley systems. Using this pulley system
http://www.swe.org/iac/images/plly_071.jpg
as an example I read that this provides a mechanical advantage of 4. If I'm only putting say 20N force in and the block weights 80N where is the other 60N coming from?
I read that Archimedes claimed he could move a ship with enough pulleys and the king challenged Archimedes to put his claim to the test and Archimedes actually managed to move a ship with pulleys. What kinda pulley system would he have used in that scenario?
You're applying a force of 20N to 4 strands at the same time.
It's leverage, similar to gearing or levers. You condense a lot of motion into a smaller movement. If you have a lever, like a crowbar, you can move your hand 4x as much as the object the other end of the bar is moving. With gearing, you can have 4:1 gearing where the motor spins 4x for every rotation of the output shaft.
With the block & tackle, you pull on the rope with 4x the movement of the lower-pulley. So 4ft of cable-pull gets condensed into 1ft of lift for 4:1 leverage.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
