Particle Energy on a Smooth Sphere: Finding the Point of Departure
  • Thread starter bernvall
  • Tags
    Energies
In summary, the problem involves a particle placed on a smooth sphere and asked at what point it will leave the sphere as it slides down. The solution involves finding the centripetal component of the gravitational force and using conservation of mechanical energy to find an expression of the form sin θ = constant or cos θ = constant. Using the inverse trigonometric functions, the angle θ can be found, which is the point where the particle will leave the sphere. The problem can also be solved in rectangular coordinates if needed.
bernvall
A Particle is place on a smooth sphere of radius b at a distance b/2 above the central plane. As the particle slides down the side of the sphere at what point will it leave?
potential and kinetic energies
no idea
The particle leaves the sphere when the normal force is zero. So the only force acting on it will be the gravitational force.
Find the centripetal component of the gravitational force as a function of the angle theta. Then write the expressions for the conservation of mechanical energy, and use the fact that F = (mv^2)/b. A few mathematical manipulations later, you will find an expression of the type sin θ = constant, or cos θ = constant. Use the arc sine or arc cosine functions accordingly to find θ. That will be your answer. You may transform to rectangular coordinates if the problem asks for it.
I know it sounds like a lot of work, but it actually isn't.
Thanks, i actually managed it, it came b/3 :)
Thanks for the help.
1. What is energy?
Energy is defined as the ability to do work or cause change. It can take many forms, such as thermal, mechanical, electrical, chemical, and nuclear energy.
2. How is energy measured?
Energy is measured in Joules (J), which is a unit of work or energy. Other common units of energy include calories, kilowatt-hours, and ergs.
3. What is the difference between potential and kinetic energy?
Potential energy is the energy an object has due to its position or state, while kinetic energy is the energy an object has due to its motion. For example, a ball at the top of a hill has potential energy, while a ball rolling down the hill has kinetic energy.
4. Can energy be created or destroyed?
No, according to the law of conservation of energy, energy cannot be created or destroyed. It can only be converted from one form to another.
5. How does energy impact our daily lives?
Energy plays a crucial role in our daily lives, from powering our homes and transportation to providing the resources we need for food production and manufacturing. It is also essential for our bodies to function and for the Earth's natural processes to occur.
