Simple RC Hardware Circuit Understanding -- Questions
37 replies · 5K views · last reply
PhysicsTest
TL;DR
Need to understand the hardware circuit
I need to understand the below hardware circuit
LTspice schematic of an RC circuit with two voltage sources labelled Signal1 and Signal2, a 0.1Meg capacitor C1, resistors R1 100 and R2 1k, output node, and a 0.1Meg capacitor C2 to ground, with a separate 4.7k and 4.7k resistor divider R3 and R4 fed from source V3 at 5.
I am not sure about the type of the signals at signal1 and signal2, i have assumed DC signals initially. Then when i simulated in LT spice, the signal at Output is +5V. But if i assume the signals at signal1 and signal2 as Sine wave, then C1 and R1 will be like a filter circuit, am i correct? But what is the main purpose of the above circuit? Some information i decoded is signal1 and signal2 are coming from the connector, and they are Current transformer signals of the phase currents. Please help me to decode this.
If V1 and V2 are AC sources that can be different, it is not good to have them directly driving the capacitor C1 (which is an AC short). Is this just a practice circuit that you made up?
I am not sure if the signals Signal1 and signal2 are AC or DC, if AC signals are not correct, then they should be DC signals and if they are same,could you please tell me the purpose of the circuit if they are DC signals?
In the actual circuit V1 and V2 are not mentioned only for the simulation purpose i have added V1 and V2. The connection at output is going to the micro controller.
Can you please provide a link to the original source.
It is a schematic given by friend to decode. I am only picking in parts to understand.
It would help if we could see the whole schematic and know what the intended purpose is. Looking only at some parts of a circuit may not may not be useful.
C1 and C2 have values of "0.1 Meg" farad ?
Are you sure those should not be something smaller, like maybe 0u1 farad ?
  • Wow
I want to understand a circuit but no one is explaining that. I know it may have impact with remaining circuit, but I am not interested right now, just want to understand the behaviour of the circuit.
Beyond the capacitor value errors, you have drawn the circuit with 3 inputs and no outputs. How are we supposed to guess what transfer function you want to discuss?
The output is below R2 which goes to micro controller.
If they are not inputs in the actual circuit, it is probably not a good idea to include them in the analysis. So your input is V3 and the output is the labeled node above C2? And what are the corrected values for the capacitors?
I think my English is bad, Signal1 and Signal2 are inputs(if they are DC or AC I do not know), output (output in schematic) signal is going to micro. V3 is the 5V power supply.
Well, the circuit still makes little sense to me. If V3=5V, that sets the bias voltage between R3 and R4 initially to 2.5V. But having V1 be a DC power supply then makes no sense, since that voltage is already set to 2.5V. But if V1 is an AC source, then it makes no sense to have V2 where it is, since it is an AC short via C1. So as drawn, I don't think V1 can be either AC or DC, and similarly V2 makes no sense where it is placed.
If there were no V2 source and V1 were an AC source, you could calculate (and simulate) the transfer function from V1 to the "Output" node. It looks at first glance to be a sort of a bandpass transfer function, with some modifications.
Again, it would be best to see the whole original circuit diagram, hopefullyl without the capacitor value errors shown on your LTSPICE rendition of the circuit.
Aside from the many practical issues raised, which I'll leave to others, this is just an electrical network problem. You can express each component with it's complex impedance and find what you want with the normal circuit analysis tools (KVL, KCL, Thevenin-Norton source transformations, etc.). If you just view this as a math problem, it doesn't matter what the voltage sources actually are; ##v_1(t)## is a perfectly adequate variable name. If you have numbers to put in, like ##R3=4.7K##, then you'll do that as the last step.
Are you familiar with complex impedance values?
My personal preference would be to redraw that schematic with inputs on one side and outputs on the other side. That can make the analysis quick using some obvious shortcuts. What can you see about the node voltages? Do you actually care about every detail, like the current through R4, for example?
Hand-drawn circuit schematic with voltage sources v1, v2 and v3 to ground, resistors R1, R3 and R4, capacitors C1 and C2, nodes A and B, and an output labelled out.
PS: Sometimes simulators aren't worth the effort required. Don't go down that path (ever) without first thinking about the circuit in question. I claim there is no better way to understand a network like this that to at least try conventional network analysis first. Use the simulator when you have to, not before.
I claim:
The first step must be to identify what the circuit is required to do.
The second step will be to draw an accurate schematic.
The simulation step requires the first two steps be completed.
We have been given an incorrectly drawn schematic, for an unspecified task.
In this case, explaining how the circuit actually does it's job, is impossible.
Agreed. And the OP refuses to post the full schematic as he received it, saying that he's only posting "the part that he wants to understand", after he has converted it incorrectly into an LTSPICE schematic to try do understand with simulation. I'm about to close this thread and issue a warning/infraction, unless the OP comes back with a very satisfying reply...
Yes, the words of the OP make no sense at all.
Please find the circuit copied in the path . RA0, RA1, RA2 go to the micro controller. Is the circuit correct? If it is wrong i will stop analyzing.
Where do the Current Transformers connect to that circuit? It's for a 3-phase AC Mains current measurement device?
I am not sure I only have this part of the circuit. Target is to write firmware to display current, but I am not able to understand the conversion formula. Will I be able to do with this part of schematic? What else I need to know?
How would we know what you want? Sure, whatever, it can be correct if you like.
You'll get better answers if you ask clear complete questions.
Okay, as you can tell we are very frustrated with the incomplete information you are providing, but since you are trying to learn, I'll try to make a couple of guesses and try to get you to the next steps. Lordy.
So, Current Transformers come in two types -- with and without "burden resistors". Those with burden resistors expect to be coupled into fairly high impedance measuring circuits, and use the burden resistors to convert the sensing current into an output voltage that you read with your microcontroller (uC).
Current Transformers without a burden resistor are meant to be used with your circuit that senses the output/secondary current of the CT, per the datasheet specs of the CT.
For CTs that have a burden resistor, they will specify what the conversion transfer function is, very typically you get 0.333Vrms output voltage for a 10Arms (or whatever current) input with a single wire turn through the CT core.
So the schematic you posted is ambiguous for CT measurements in several ways. First, the resistances and impedances of that circuit are medium, so too low to be used with CTs that have a burden resistor integrated, and strangely high for a raw CT. Whatever.
And since you are not able to explain how the three CTs are connected for the 3-phase current measurement, my best guess is that each CT has one side (non-dot side of the winding) grounded, and the other (dot) side connected to the schematic nets 4-5-6. This would give you an AC input voltage at AC Mains frequency on each of those "inputs" to the circuit, with a filtered version available at the three nets that you say are routed to your uC for digitizing.
My take on the CT interface diagram in post #18 is as follows.
R1 with R22 divider produces DC bias = 2.5 volts, with R thevenin = 4k7 / 2 = 2k35
C1 = 0u1 farad; in parallel with; R19 = 10E = 10R = 10 ohm, (1/4 watt); is the burden for the CT. Shown as terminals 1 and 6.
R24 = 1k; in series with; C6 = 0u1; forms a low pass filter to the analog input port RA0.
Note that the Rth of 2k35 is in series with the 1k, so low pass has R = 3k35 with 0u1 F.
Software must discover the exact input voltage for zero current since 4k7 dividers are otherwise uncalibrated.
Thank you very much for the clarifications, I am very poor in analyzing the circuits, hence based on the comment provided by DaveE i rearranged the circuit as below which was really helpful approach i have to follow,
Schematic of a circuit with a 1k resistor R24 to RA0, a 0.1µ capacitor C6 to ground, a 10E resistor R19 and 0.1µ capacitor C1 to node 1, and a divider of 4K7 resistors R22 and R1 with a 5V source V1 to node 6.
Regarding the primary current calculations this is the formula i came across
##R = \frac{V_{CT}*N} {I_p}##
##I_p = \frac{V_{CT}*N} {R}##
So for example if i measure ##V_{CT} = 1.25V, N = 1000, R = 10##
##I_p = \frac{1.25 * 1000} {10} = 125Amps##
Are the above calculations correct?
I did not understand the statement
How do i do this?
We. are. not. mind. readers.
If you're asking if ##\frac{1.25 * 1000} {10} = 125##, then yes. That's what my calculator says too.
OTOH,
I don't know what ##R## is.
I don't know what ##V_{CT}## is.
I don't know what ##N## is.
I don't know what ##I_p## is.
I don't know what's connected to terminal ##1##.
I don't know what's connected to terminal ##6##.
I don't know what's connected to terminal ##RA0##.
I don't know what "##10E##" means when you write that next to a resistor.
I think I have a pretty good guess, but what's the point in my guessing in order to check your work.
Me either. In fact, I don't even know what the statement was.
Try again. Better (complete) questions will get better answers.
OTOH,
This is as per post #25, R is the burden resistor
This is the Current Transformer voltage read by the micro controller. Here for example i am assuming the micro is reading a voltage of 1.25V.
N is the number of turns assuming it to be 1000, for calculation
This is the primary current flowing from the phase terminals. (R,Y,B), which is want i have to calculate and display on LCD.
These are connected to the current transformer phase terminals.
This will go to the micro controller ADC input pin.
This is 10 Ohm resistor.
How do i do this?
The voltage to the analog input when no current is flowing in the CT will be close to 2.5 V. The resistors in the voltage divider may be slightly different, so you need to find just what voltage represents zero current. Without the CTs being connected, read each analog input to identify zero for each channel.
Note that a CT will often have an internal resistor of maybe 470R, that is to protect the insulation from overvoltage arcs if you unplug it from the burden on the PCB. That unknown protection device may change the calibration scale slightly.
Avoid decimal points. "0.1μ" is better written in LTspice as "0u1". It may then be displayed as "0μ1" if that option is turned on.
Avoid the exponential "10E", use instead the more common "10R".
"10E" is actually a suppressed zero exponent, floating point "10E0" = "1E1" = 10.
Never put units on component values, or on voltage and current sources.
1F is not one farad, it is one femtofarad. 1A is not one amp, it is 1e-18 amp.
  • LTspice schematic of an AC current source Icts feeding C1 (0u1) and R1 (10R) in parallel, a 2.5V divider of R3 and R4 (47k) from V1 (5), and R2 (1k) to a low-pass filter output with C2 (0u1); directive .ac oct 100 1u 100.
  • LTspice AC analysis plot of V(out) from 1 Hz to 100 Hz: solid magnitude curve falls from 0.0 dB to about -5.3 dB, dashed phase curve falls from 0 to about -58 degrees.
  • LTspice schematic of a CT burden circuit: sine current source Icts feeds C1 0u1 and R1 10R, with R2 1k and C2 0u1 forming an RC low-pass output labelled LPF and out, and R3 and R4 47k divider from V1 5 setting 2.5V bias.
  • Simulation plot of two sinusoidal waveforms over 0 to 50 ms: V(out) in green on the left 0 to 5.0V axis, and I(lcts) in yellow on the right -300mA to 300mA axis, with the current peaking slightly ahead of the voltage.
I am trying to solve the schematic manually using node equations
Circuit schematic with a current source Icts feeding node C1 and R1 to ground, a 2.5V node fed by R2 and R3 from a 5V source V1, and R4 (1k) to output node out with C2 (0µ1) to ground.
The current through C1 is i1, R1 it is i2, through R4 is i1+i2+icts.
##V_{C1} = V_{R2}##
##\frac{\int{i_1} dt} {C_1} = i_2 R1## -> eq1.1
##2.5 - i_2R_1 - (i1+i2+i_{cts})R4 = V_{out}## -> eq1.2
##i_{cts} + i_1 + i_2=0 ## -> eq 1.3
Are the equations correct to solve for ## V_{out} ##.
  • LTspice-style schematic of an RC low-pass filter: AC current source Icts, C1 0.1 µF and R1 10R in parallel, R2 1k into C2 0.1 µF to ground labelled LPF, output node out, plus a 2.5V divider from R3 and R4 47k to V1 5V, with the simulation directive .ac oct 100 1u 100.
