MHB How do you solve the recurrence relation P(n) = 1 + 5n by induction?
  • Thread starter Thread starter Fernando Revilla
    Recurrence Relation
The recurrence relation P(n) = 1 + 5n is solved using mathematical induction. The base case shows that P(1) equals 1, confirming the formula. The induction step assumes the formula holds for n, then demonstrates it also holds for n+1 by showing P(n+1) equals P(n) + 5. This confirms that the closed form solution P(n) = 1 + 5n is valid for all n. The discussion effectively outlines the steps of induction to validate the recurrence relation.
Fernando Revilla
MHB
I quote a question from Yahoo! Answers
Solve P(n) = 1 + 5n by induction?
Closed form solution: P(n) = 1 + 5n
from, P(n) = {1 if n = 1
P(n-1) + 5 if n > 1}
I have given a link to the topic there so the OP can see my response.
Mathematics news on Phys.org
The recurrence relation is $p(n)=p(n-1)+5,\; p(1)=1$. Then, $p(n)=1+5n$ is a solution.
Basis Step $p(1)=1+5\cdot 0=1$.
Induction Step
Suppose the relation is true for $n$. Then, $p(n)=1+5n$, so
$$p(n+1)=1+5(n+1)=1+5n+5=p(n)+5$$
As a consqeuence, the relation is true for $n+1$.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
