qems
- 1
Hi, great forum
My apologies for my first post being a question, but I am trying to calculate the size of a Steel Universal I-Beam that I will need to replace an old wooden beam.
It is a simply supported beam that needs to hold up a uniformly distributed load of around 1.5tonnes, over a length of 14.5ft. The beam is supported at either end by an upright column.
I have calculated this weight using the following:
Surface Area of Slate & Wood Roof = 103 sq ft @ 16lbs / sq ft
= 1624 lbs
Surface area of Wood Panal and Partially Glazed wall = 100sq ft @ 6lbs / sq ft =609lbs
TOTAL Weight = 2233 lbs
Safety Factor = 2233*1.5
= 3349lbs
(I also included an assumed live load of approximately 40lb sq ft, but did not show this in teh calculatiosn above.)
I have tried using BM = wl^2/8 and D= 5/384 x wl^3/EI , but I am not having much luck as I am getting figures that say a 203 x133 will be sufficient but this seems light.
Any help would be greatly appreciated. If you could show me the calculations it would be fantastic so I can see where I am going wrong.
Rob
= 1624 lbs
= 3349lbs
Rob
