Simple vector arithmetic question
  • Level: High School
  • Thread starter Thread starter The_Engineer
    Arithmetic Vector
4 replies · 2K views · last reply
The_Engineer
I have two vectors: a = <ax, ay, az> and c = <cx, cy, cz>
which have an angle of 45 degrees between them.
If I get another vector by b = c - a then shouldn't b be orthogonal to a? I'm assuming this since a + b = c
Did you try to sketch some vectors and to come up with a counter example?
Yes I have been using MATLAB to sketch and generate random examples. Here is one...
a = <0.3814, 0.9023, 0.2010>
c = <0.3965, 0.7378, -0.5463>
The angle between these vectors is 45 degrees.
I want a vector b such that b is orthogonal to a AND 45 degrees from c. Graphically speaking, this means a + b = c
Solving for b,
b = c - a = <0.0151, -0.1645, -0.7473>.
But b dot a ≠ 0 therefore they aren't orthogonal. Why aren't a and b orthogonal?
This happens for every random sample I make, starting with 2 vectors that are 45 degrees apart.
Nevermind I figured it out... I made a mistake by normalizing the resultant, which in turn messed up my final answer.
The vectors you describe will form a triangle. With one angle at 45 deg. the other two angles could be anything that add up to 135 deg.
